Question about Car Audio & Video
The radio is working but there is no sound coming from the speakers it was working I turned the car off and when I turned it back on no sound?
    Scholar:
  • 55 Answers
If you have high quality after market speakers with a lower impedance (2 ohm and 4 ohm) versus the factory speaker impediance (8 ohm 12 ohm and 16 ohm) your headunits sound out device is probably fried inside your head unit. that or all your speaker leads are fowling out at the same time which i would find that hard to believe. But the good new is, some of the newer head units have a low impediance fail safe, so you could have one speaker that is fowled out that is sending the head unit into protection mode which is muting the output until the fowled wires are cleared. Disconnect your speakers and turn the head unit up playing a cd or something, then connect each speaker one by one. You should have sound. hope this helps.
Posted on Aug 08, 2010
Plz help. 2004 saturn vue. one night the radio is working just fine the next morning I got in the car the radio comes on but there is no sound coming out of the speakers I've checked all the fuses and...
With the radio on, make sure there is voltage at the speaker wire positive and negative leads. If there is no voltage, the output from your receiver might have gone out.
Feb 12, 2015 | 2004 Saturn VUE
Only tweeters are working while playing radio. No other speakers are working. ...radio operates normally, turn on , cd, all options work. What could this be? It's a 2006.
all speakers r connected to the same wires on the radio
If left/right balance and front/rear fader work properly
and sound is coming out it is likely (but not definite) radio is ok and speaker wiring is the issue.
HOWEVER, if it sounds the same on both left and right, it could be the radio. It is unlikely both sides have the same issue at the same time without it being in the radio.
The only way to verify it to disconnect the speaker and substitute a known good speaker.
So back to troubleshooting.
Dec 09, 2014 | Cars & Trucks
My radio stopped working
Could be speaker fuse or fuses esp if played loud with bass turned up worst case is power transistors blown then you may as well scrap it considering cost of repair vs second hand radio. Look at wires coming out of back of radio to speakers for inline fuse holders push and twist to open.There could be a fuse in rear panel of radio. Sorry I can't tell you how to remove the radio
Apr 14, 2012 | Cars & Trucks
My 2005 accord's radio will power on, but nothing is coming out of the speakers. at one point the speakers would produce a sound and then cut off and even after having this problem was able to turn off...
If you remove the radio, you could check the speaker wires with an ohmmeter to see if any of the wires are shorted to chassis ground. If they are not, the radio is the problem.
Sep 14, 2017 | 2005 Honda Accord
No sound is coming out of the speakers when I turn the radio on. Is there a fuse that might need to be replaced? The radio display is working so I think it might be the speakers.
The radio has a amp. fuse built into the back of the radio. Cant tell you how to remove the radio without
more info about the car and the radio. The fuse is blade type located next to the control plug.
This could be your problem as blown speekers still make some noise normal sound is crackling if blown
hope this helps
please leave feed back
Dec 03, 2009 | 2003 Mini Cooper
1998 bravada has six radio speakers; two dash speakers and two in the front doors speakers plus two rear doors speakers. the front doors speakers work good but no sound come from the dash speakers or the...
Did it fail while you had vehicle, or like this when you bought it? Could be bad radio or wiring harness was chopped up when previous owners had an aftermarket radio installed. They probably just slapped the OEM radio back in when selling car. And didn't put all the OEM wiring back in.
Nov 07, 2009 | 1998 Oldsmobile Bravada
Radio/Speaker Problem
Check your radio and trunck to see if you have a equalizer/amplifier built in or otherwise.Adjustments would cause radio to go into safety mode.Try your balance from side to side.A busted speaker would cause the fuzzy sound or a shorting speaker wire.If none of this is your problem you may need to take it to a sound specialist.
Apr 20, 2009 | 1994 BMW 5 Series
1996 chevy blazer radio turns on but there is no sound
I have a strong feeling that the head unit "radio" has finally gone bad. You describe a situation, in which you have to turn it on and off, to get it to work. Typically if the sound comes out of all speakers, after doing that, then the speakers were never broken. The head unit itself should be replaced. I hope this helps.
Nov 16, 2008 | 1996 Chevrolet Blazer
Cracking sound from Radio Speakers
I disconnected the amp and ran jumper wires for the proper speakers (two wires per speaker eight total) . Basically I bypassed the amp now all speakers work and sound fine.
Jul 10, 2008 | 2006 Chevrolet HHR
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
