Best Solution
posted on Apr 28, 2008
Thanks for replying so promptly.I just needed to know how to use the machine that was given to us ,w/o the instruction book. I figured it out yesterday.Thanks again for your reply.
Rating Locked! (?) Karen7 has rated this solution as Thanks for Trying
Solution #2
posted on Jun 21, 2008
I think I've figured my yard sale EX 80 out. First, the way I think it works... in the tightly sealed boiler the water is heated to boiling, it must have a pressure release valve that sends the water/steam through the coffee and into the carafe. So dangerously hot and under pressure. Before opening the big round cap at the top (reservoir) relieve pressure at the steam tube valve (right side)
Here's how I made my first batch:
When opening reservoir always turn unit off, let reservoir cool a little between batches or you may get a cloud of steam in your face when pouring in water, might not be good for the heating element to shock it with sudden drastic temperature changes either.
Cleaned by running a couple of jugs of water through, cold water (4 on the supplied jug) into the reservoir all parts installed. I read somewhere online (not specific to any machine) not lukewarm water, if it's online it must be true... right?
Put coffee into filter basket/basket holder, matching amount of water in reservoir, 2 or 4 (markings on filter and jug). Espresso coffee should be very finely ground
Install all covers and the coffee basket/filter basket, close steam tube valve, install carafe and turn on the machine. Should get blast of espresso after a couple of minutes.
The steam tube (operated by the valve) seems a little cheesy on first try but I'll get better with practice. There's no steam to the tube until the reservoir starts to send steam to the coffee, the coffee kinda restricts the steam enough to send it to the tube. I was thrown a little because I didn't get steam when I was cleaning the thing, but I think that was because there was no coffee to block the flow. So I opened the valve at the start of the brew, steamed the milk, closed the valve and then the steam blasts through the coffee, tasted good.
Great $1 find.
Hope this helps.
Great $1 find.
Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Salton EX80 Espresso Machine
Email this problem
Email this problem
Can you Help with these Coffee and Espresso Makers problems?
repair to delonghi coffee maker...
hi i purchased a delonghi... Answer This...
kenmore coffee maker . press...
kenmore coffee maker 12 cup... Answer This...
Missing grounds basket lid?
I picked up this espresso maker... Answer This...
Repair Service
Find Coffee and Esp. Repairman Near You:
