Question about Samsung T220HD LCD Monitor
I am trying to trouble shoot a Samsung T220HD, the unit will not power up at all, new power cord, appears to be totally dead.
    Genius:
  • 1,121 Answers
Is a power supply transf problem. needs to be check inside. seek for burned fuse.
Posted on Aug 07, 2010
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
What should i do when my television doesn't turn on?
if your unit is dead set totally no power at all even led indicator the first step is check your AC outlet make sure the supply is present then check broken AC cord for your TV unit. then next step is to open the back cover for trouble shooting, try to use your senses first to diagnose defective part smell burnt parts, wirings, connector or even PCB. look for blown fuse and leak capacitors especially the output filter capacitor at the power supply which cause sometimes by over heat where in the capacitor casing explode, the temperature was exceed to the rating.and then use digital tester try to power on check the output voltage of power supply if present and normal according to its label.
Apr 28, 2011 | JVC Televison & Video
My Samsung T220HD was having problems turning on. The red light would flash once instead of 3 times, there would be an odd sound, and the screen would look a little weird. I would have to wait a few...
Many times the main circuit board becomes defective, especially after a power surge. If you had power fluctuations lately, the board could have become compromised. A shorted board needs replacement. Sometimes the cost of repair becomes greater than purchasing a new system.
Jan 14, 2018 | Samsung T220HD 22 in. LCD TV
Hi, i have a samsung T220HD , its working for 10 months and then the power on button just wont works , the led flashes up , and dies how can i solve this ? help will be greatfull thx !
Bad capacitors are a very common problem. They're like buckets that fill up and store energy so other parts have power to do their jobs. When the capacitors go bad they don't charge or a very slow to charge, and this can be your trouble. This site addresses his exact problem on your model, so you can see if self-repair is something you'd like to try. Good luck, and thanks for using Fixya!
Jan 06, 2011 | Samsung T220HD LCD Monitor
There is zero power to the monotor. I tried a new cord and tried the cord from the monitro on something else. Cord works...outlet works...It is the monitor itself. The little round on/off button DOES NOT...
The monitor has a power supply problem, if you are very lucky it might be a fuse. To access remove back cover follow the power cord to the power module and there should be a fuse close by, if changing fuse fails, replace monitor "repairs not cost effective"
Jan 05, 2011 | LG L1920P 19" LCD Monitor
Samsung T220HD unreliable power-on and freak volume turn-down
Good news. These monitors come with 3yr warranty. Contact Samsung.. I just did.
Jan 12, 2010 | Samsung T220HD LCD Monitor
No power to Samsung FP-T5084
I had the same problem twice with my Samsung FPT 5084 and it was the 12 AMP fuse on the power board both times. The bad part is you have to remove the whole back plate to get to it but once off it sits on the power board (dead center) towards the lower left hand side of it. Replace the top fuse or you can replace both. They're just regular ceramic sealed 12 AMP fuses that cost about 50 cents each.
Jan 22, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Samsung LN-T5265F
Samsung LN-T5265F S POWER SUPPLY UNIT BN44-00150A
Aug 19, 2008 | Televison & Video
Samsung T220HD LCD Monitor Logo
346 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
