Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker does not make ice. Filtered water in door works fine,
    President:
  • 1,099 Answers
HI,
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension.
2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only.
3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost.
4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad.
5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!!
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install.
Follow these steps and this will solve your problem.
Take care.
Posted on Aug 07, 2010
Filtered water will not dispense
If your ice maker is working your filter is fine. You need to check the solenoid valve that feeds the water dispenser. You should have 2 of them on the water line. One that feeds ice maker and one that feeds the water dispenser. That is most likely your problem
Jan 21, 2018 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge is making Ice and will dispense Ice. Fridge will not dispense water at the door.
. Check your water filter first . On some models , only the drinking water is filtered . I don't know which model you have therefore you'll have to check and see if your ice maker water supply is filtered or not . If it is not , that is probably a bad water filter you have . However , if it is , I would check the supply line from the chiller located in the refrigerator compartment usually on the lower right hand side at the back of the compartment . The problem could be a plugged supply line from the chiller to the water valve on the door .
Mar 10, 2011 | GE Refrigerators
The ice maker does not produce ice. The arm moves up by itself after I move it down. The filtered water spigot works, so I assume the ice maker is getting water. How can I remove the ice maker from...
Water valve has 2 solenoid so solenoid for water dispenser could be working and one for ice maker may not be. Visibly inspect ice maker to see if water is in it.
Nov 11, 2017 | Jenn-Air JFC2089HP Bottom Freezer French...
No water in automatic ice maker, therefore no ice cubes.
Do you get water at the front dispensor, if present? If not check the refrigerator water filter. If you have an RO system feeding filtered water to the fridge, check it's filter. Also there is a solenoid that lets water into the ice cube maker, have a professional check it to make sure its working correctly. Lastly I have had to replace the entire ice cube maker, sometimes they do fail. Replacements can be found fairly easy on the internet.
Feb 21, 2010 | KitchenAid KUIS18NNT 18" Automatic Ice...
Not getting any water out of my dispenser. The light indicator is on but when I push in the dispenser lever no water comes out??? My ice despensor is working fine, Indicator lights are working fine. I...
I have the same problem with the same refrigerator, call up GE Customer Service and tell them that you want part number WR49X10173, a water dispenser heater kit. They should sell it to you for a "discounted" price of $25. Good Luck, and don't ever by GE anything ever again.
Jan 15, 2010 | GE GSH25JFT
Ice maker is not working - not making ice - water dispenser is working fine
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
te95
Dec 07, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice maker problem
let it run its caused by stagment water in the system it will clear over time.
Feb 09, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
69 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
