Question about Garmin Nuvi 660 GPS Receiver
Suction cup for windsheild attachment - Garmin Nuvi 660 GPS Receiver
  • Garmin Master
  • 589 Answers
Get one from www.MyGarmin.com
Posted on Oct 20, 2010
Need replacement suction cup for window attachment.
Contact the radar detector manufacturer for replacement suction cups. You didn't mention which make and model radar detector you have so we can't provide more information.
Jul 16, 2015 | Vehicle Parts & Accessories
Mounting of gps can't mount on windsheild.
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
Jan 04, 2011 | Tomtom ONE XL GPS
How to replace windshield on 1998 toyota 4runner
mcdevito75 Here, Windsheid Change, a major job, first you:ll need the tools to remove and replace the molding around the windsheild, then you"ll need suction cups or a helper to align the new windsheil, then you"ll need the commercial adhesive to seal the windsheild, Best Bet let your local Glass repair shop do the job.
Jun 18, 2010 | 1998 Toyota 4Runner
Suction cup does not stick to the base of the tom tom..Everytime I try to attach the suction cup, it just falls over. Help
  1. If you will stick the suction cup to your windshield make sure to clean it first use dry clothe and put pressure while rubbing it to the windshield.
  2. After cleaning it before you stick the suction cup to the windshield make sure the lock is release and then put a pressure and then while pressing it then that's the time you will lock it.
Feb 06, 2010 | Tomtom ONE GPS Receiver
I got the standard mount with TomTom GO 730 and it just does not seem to work. The first time I had placed it on my windshield which I was later told was the wrong place to put it (the included maual in...
This is a fairly common issue especially with aftermarket tinted car windscreen 'film'.
You can try prolong the suction by wetting the suction cup with water of very slightly soapy water before applying it to your 'clean' windscreen area.
As for the dashboard, for some models, TomTom provide a plastic circle to which the suction cup attach to. The plastic circle is first 'permanently' attached to your dashboard with double-sided adhesive tapes.
Hope it helps: let me know how you go.
Jan 08, 2010 | Tomtom GO 730 Car GPS Receiver
There is a black disc but I do not see any instructions for using it.Does it mount on the windshield?
my Magellen came with a black disk with adhesive on 1 side. Intended to be adhered to any smooth surface (e.g., windshield). The mount for my unit includes a suction cup. So, mount black disk to windshield and attach suction cup to smooth side of black disk. Be sure disk is positioned where suction cup and bracket and GPS will have sufficient room to mount everything.
Jun 05, 2009 | Garmin nuvi 255W GPS Receiver
Tom tom gps adhesive plate
Use an 'alcowipe' available from your local chemist.
The alcohol in the wipe will disolve the glue and will not affect your windscreen.
Aternatively get a bottle of 'Spirit Alcohol', also available from the chemists and use a cloth to dissolve the glue
Feb 25, 2009 | Tomtom XL 330 Car GPS Receiver
LG GPS not suctioning to windhield
You must clean the window area using windex, or other cleaner, and wipe until dry. A clean winshield area provides the best suction, from the mounting bracket.
Slide the mounting bracket switch to Off & On a few times, make sure the suction cup is able to move(slightly) and that the small tap is facing the area with the notch in the metal.
After putting the switch to the middle, moisten the suction cup slightly
(saliva works bestter than water for some reason)
press it to the window with a slight amount of pressure
then move the switch, (Which should be set to Center!)
to lock it on firmly.
If this doesn't work, then there is a good chance the suction cup has become hardened by the sun. If that is the situation, you'll have to contact LG
(or a place that sells "knock off" brackets to get a replacement.)
I never leave my LG GPS in the car, when not in use. Even the bracket comes out, as I've seen what the sun can do to damage those plastic suction cups, fortunately, I learned it on a $5 replacement set for a Radar detector/Emergency Vehicle Alert device, and not a more expensive bracket.
Dec 07, 2008 | LG LN740 GPS
Attaching to windscreen
I have a spare window mounting bracket as new , but I need SmartST 2006 SE CD Rom. If you want to do a swap , that is you send me a copy of SmartST 2006 SE and I send you bracket email me at
fuddlebarklard45@hotmail.com
Aug 29, 2008 | Navman NavPix N40i GPS Receiver
Holder
wet the suction cup a little, press down firmly before flipping the switch to lock it down
Apr 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
19 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
