Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
I have a Ryobi 30cc string line trimmer model # 0304AB 2005 model. After cleaning the carborator and replacing the fuel line, I found two needle values that need to be readjusted . Which of the two values has a spring on it? And how many turns out to adjust each value? Thank you
    President:
  • Ryobi Master
  • 1,545 Answers
A good starting point for the Hi and Low speed jets is about 1 and one/half turns OUT from a lightly seated (all the way turned in) position, Never overtighten these as the tips can be damaged. This setting should enable it to start and if one jet had a spring on it, the other one should have one also. Maybe state carburetor/model #'s in another post?
Posted on Aug 08, 2010
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
I inherited this trimmer and do not know how to add new string. There isn't any kind of a manual that we can find. The trimmer is a RYOBI 137R. Thank you.
hi i have a ryobi rlt 30cd strimmer and when i was useing it it just stopped it as fuel in it but ive cleaned the carb but i still cant get it to run as any one got any ideas thanks
Jul 15, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
The fuel is going into the arb but when i try to start it nothing happens. I can start with starting fluid but then it quits out.
I would check or replace the fuel filter and also check your Air filter too. the fuel filter should be at the end of the fuel line in the tank. If that wont work try cleaning the carb
Jun 15, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Won't start , can not get primer to work even after replacing primer bulb.
If your fuel filter is clean, and none of the fuel lines are pinched, then you probably need to replace the diaphragms, gaskets, and screen in the carb. Some carbs with the primer bulbs mounted on the carb have a check valve in the primer system. This is the least likely problem, but it is possible that the check valve is defective.
May 07, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
325 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
