Question about Brother GX-6750 Typewriter
Typewriter runs its own commercial, how can it be stopped?
How does one overide the commercial message about this typewriter that prints at random when I try to type something?
    Scholar:
  • 183 Answers
The self demo mode is only supposed to activate when you hold down the CODE key and hit the ALT key. If it turns itself on at random I would suspect a problem with the main board. You might try turning off the machine, and unplugging it for at least 1 minute. It could also be a forien object or dust on the board or a bad or loose connection. in which case you would want to take it so a repair shop.
Posted on Oct 28, 2008
I have a wheelwriter 5 and it stopped printing
Can be fixed bad solenoid is likely
King Typewriter in Indianapolis, IN
Aug 13, 2014 | IBM Wheelwriter 5 Electronic typewriter P...
Stops typing mid line
Type to the stopping point, press the margin release key space to the desired location, press R. margin key.
Jan 08, 2014 | Olympia Mastertype 3 Typewriter
Sears SR2000 typewriter solenoid
If this is a Nakajima print head the print solenoid is on thr R. side of the head and the armatures crack and stop printing.
DickyO
Dec 31, 2012 | Office Equipment & Supplies
My typewriter all of a sudden just stopped typing letters. im not sure if the ink has run out...it wasn't fading or anything before it stopped working mid typing
The ribbon might have fade out, please try and replace the ribbon or check the ribbon selector if is not for stencil cutting. If is in stencil cutting it wont print on the papers as u type. Thanks
Apr 29, 2010 | Brother ML-300 Typewriter
IBM Wheelwriter 3 not striking ribbon onto page
There is a plastic cap on the print solenoid plunger that is probably broken, they are available but a little tricky to install.
DickyO
Sep 22, 2008 | Lexmark Wheelwriter 3 Typewriter
Error message on print screen of 114 08
The book says nothing about this error except turn off machine for 30 seconds and try again. If this dosen't work try unplugging machine, removing the batteries and then restart. CAUTION THIS WILL CLEAR ALL MEMORY!
DicktO
Jul 29, 2008 | IBM Wheelwriter 30 Typewriter
Typewriter won't print
see on the lamps, is the printer lamp lights
Feb 04, 2008 | Brother ML-300 Typewriter
Carriage skipping
the gear where the carriage runs along probably has a play.the shaft where the gear spins on is worn out.try to replace that mechanism.
Jan 04, 2008 | Olivetti MS25 Typewriter
Possessed typwriter
Assuming that you have the correct print wheel fitted and that the typewriter is on standard key board setting then I would look at anything that might be interfering with the rotation of the print wheel. First, remove the print wheel and check that none of the character arms are distorted,then look at how the correction tape is fitted. If this tape is not fitted correctly it could be interfering with the rotation of the print wheel.
Nov 02, 2007 | Brother SX-4000 Typewriter
Brother GX-6750 Typewriter Logo
107 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
