Question about LG LRFD25850 French Door Refrigerator
The temperature in the freezer stays at 8 Fahrenheit. The freezer is full of ice.
    President:
  • 2,702 Answers
Ok??? "full of ice "A",,,,,,well,,, lets look at it this way,,,,,,,,,,,
what if the number "one" in the display has just stoped lighting up????
now it would read -18* fahrenheit and thats about right for it????
you cant have frost above 0* fahrenheit,,,can you????? well not in my part of the world that is!!! go get a freezer thermometer and put that in there,,,if it reads +8*F or -8*F,,, the freezer is broken,, and thats likley to be the thermostat fault but if it reads -18*F,,,,,,,,,,, go kick the dog? or better still the hubby???
Posted on Aug 07, 2010
Why is ice cream not freezing in refrigerator freezer
Funnily enough, the cause of this problem won't be the ice cream! There is a problem in the temperature system of your freezer which would have to be looked at by a refrigerator technician. Unless there is something that may be jamming the door/lid which is therefore allowing warmer air to flow into the freezer, the problem is most likely to be one that is needed to be seen by a professional.
Aug 18, 2016 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer wont freeze ice cubes
Hello Friend, this is Z. Thank you for your post!
I interpret that you are having trouble with the freezer of your Frigidaire refrigerator not freezing ice cubes. It appears that your refrigerator is not properly cooling. Make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. Please allow 24 hours for temperature to stabilize. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully. Thank you!
Aug 26, 2014 | Frigidaire Freezers
How to set AEG model 7522238-GA temperature
Normal for a freezer is around 0 Fahrenheit. 21 is barely cold enough, but ok, food will stay frozen. Freezing is 32 Fahrenheit, 0 Celcius.
Nov 29, 2013 | Kitchen Ranges
MY ICEMAKER DOESNT WORK BUT THE WATER DISPENSER WORKS
Hello Valarie Nonos - The issue sounds like it might be related to the temperature in the freezer. What is it set to? Make sure that the temperature is approximately around 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. If it is properly set, then consult a professional to accurately pinpoint any potentially more serious issues like a faulty ice maker or ice maker valve.
Feb 12, 2013 | Frigidaire FRS26RLECS Side by Side...
We changed the filter for the water, now it will not dispense water, but the ice maker still works.
Hello nott225 - The issue sounds like it might be related to the temperature in the freezer. What is it set to? Make sure that the temperature is approximately around 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. If it is properly set, then consult a professional to accurately pinpoint any potentially more serious issues like a faulty ice maker valve or even the ice maker itself.
Feb 03, 2013 | Frigidaire FRS23H7CS Side by Side...
Making hardly any ice
Are the ice cubes being formed the same size as before? If freezer temperatures are increasing above 5 Degrees Fahrenheit in freezer this will slow down and at times stop ice production. Look around the rear wall of your freezer to see if a layer of frost is building. If yes this will indicate a defrost problem that in turn raise freezer and fresh food temperatures. Here is a Whirlpool Ice Maker Troubleshooting PDF You can find this info on this page HERE You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. I will be here should you have any questions, Thanks Sea Breeze
Aug 08, 2012 | Amana ARB190ZC Bottom Freezer Refrigerator
What is the proper temperature for a refrigerator be and what is the proper temperature for the freezer?
A refrigerator should maintain temperatures at or below 40 degrees F. The freezer temperature should be 0 degrees F or lower
May 13, 2011 | Amana Refrigerators
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Kenmore freezer-on-top icemaker not getting water into icemaker. I replaced the water valve solenoid with a new one, but no change. There is no AC voltage at the solenoid terminals. The icemaker itself...
First check the temperature in the freezer to make sure it is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
If the temperature is ok then the ice maker mold thermostat needs to be replaced. And yes you can replace just the thermostat.
Aug 19, 2009 | Refrigerators
LG LRFD25850 French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
