Question about Jwin JK-777 Nostalgic Stereo System with Turntable, CD Changer, Cassette Deck, and AM/FM Tuner Shelf System
Tape player never worked. Now Cd player is broken will not even opened and has barely been used! This was expensive and had good reviews but mine is a piece of ****? What am I supposed to do when I no longer have a receipt? I used this in my place of business and now I am screwed! I paid too much for this to happen. Please help!
What is the best turntable/speaker system for the money? I have a lot of LP's that I would love to play, my old Sansui system was too cumbersome and now I want a good, more compact turntable system. ...
Have a look at the hi-fi magazines. They have plenty of reviews of them.
Or you can just do an Amazon search and select by customer reviews. I tend to to do this with all electrical stuff anyway. Even if I don't buy from Amazon. The customer reviews, when in large numbers can give clues to how good or reliable anything is.
Jul 18, 2017 | Bose Wave Music System CD Shelf System
I own a Philips CD 950 player. I now cannot open or close the CD compartment. How do I remove my disc? I live in Manhattan, New York City and wonder if there is a service center near me.
The small gear that opens or closes the door goes bad after 10 or 15 years. The gear is not available separately. The solution is easy. Take the deck cover off with a torx bit, and remove the broken gear pieces. Push the CD transport door out, and fasten heavy clear mailing tape on both top and bottom of the center of the CD transport door to make a Grab Tab you can use to pull the door open. When you load the CD you are going to hear, push the door open/close switch twice to fool the deck to go into PLAY mode. Mine has worked great like this for 6 years now, and it still sounds beautiful.
Oct 03, 2010 | Philips Audio Players & Recorders
I have a AIWA brand music system model NSX-V70. It has Tape--Tuner--Video/Aux--CD facility. Problem: 1) CD changer is not operating, it is locked, not opening as a result can not play any CD or DVD. It is...
It is possible that your Cd and teh tape section has a belt problem. The loading belts of the cd and the tape transport is worrn out and results in non action. Since there is no drive the cd mechanism nor your tape mechanism will work. If you have a help around ask them to open the top cover, remove the tray and look inside for the loading motor of the CD. replace and keep the Cd section out. by removing the connecting corrds very carrefully. ZThe tape deck mechanism is within and you will see the belt worn out. The front panel and the deck assembly can be taken out and the belts can be replaced. Attempt to do the job only if you are familiar with electronics other wise get help from a good reputed service shop to replace the motors. However this is not a expensive work but must involve great caution not to damage any parts with inexperience. I hope you understand and find this helpful. Pune is a great place and if you look around find a good sincere technician to help . Good day
Mar 24, 2010 | Aiwa Audio Players & Recorders
How to remove broken key from the ignition switch of a 1996 Mitsubishi eclipse Turbo?
e
if it's broken off just to the inside of the ignition, try using two sewing needles. use them like prybars one on each side. even try a strong magnet. duct tape pushed into the lock to the key might even work. if know one knows but you and you can still start and lock and unlock the car why worry.
Also can review this TIPS GUIDE
I hope helped you (remember rated this help) Good luck.
Oct 15, 2009 | 1996 Mitsubishi Eclipse
Chevy Cavalier Cassette Player
The tape player is probably broke. There may have been pop spilled in there and got it all sticky inside. Use a maglite and look inside the tape player for this or bad dust etc. You will have to replace the player, and you might as well get a cd player since it will not cost you a ton these days. You can use an mp3 player or ipod today, but if you want to use cd's, then install a cd player. You should be able to do this pretty cheap now, maybe $40-60 bucks or so.
Jun 06, 2008 | 1996 Chevrolet Cavalier
Broken
face is damage u will need a new face plate i had the same problem. i have a working face plate for it $160
Dec 03, 2007 | JVC KD-AVX1 Car DVD Player
CD Carousel for the Onkyo Shelf System
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Oct 11, 2007 | Audio Players & Recorders
CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Nov 19, 2006 | Teac PD-H300 CD Player
Jwin JK-777 Nostalgic Stereo System with Turntable, CD Changer, Cassette Deck, and AM/FM Tuner Shelf System Logo
19 people viewed this question
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Oloyede Monsuru
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
