Question about Samsung DV438AER Electric Dryer
Samsung DV438AE dryer not getting hot? please help. Checked breakers.
    President:
  • 2,702 Answers
If dryer is running check the outlet pip is clear and all inlet filters are clear the dryer must be able to "breath freely" if this dont help you need to check the heaters are working and the thermocouple is good if the dryer has over heated the thermocouple will have cut out or poped!
Posted on Aug 07, 2010
Dryer not getting hot
There's a thermal switch on the elements or the elements themselves may have burned in two and need replacing. Unless you know something about electrical and controls, I'd get a pro to check it...
Mar 19, 2014 | LG Dryers
Gas dryer pops circuit breaker
Number 1 Do NOT! use this dryer until it is fixed, it a a fire hazard. You will need to get the entire power circut checked for shorts. Make sure the motor has been checked under the same conditions as it is used in the dryer, with a capasitor and changing directions etc.
NEVER EVER !!! Change a Circut breaker with a higher value than the one which is there. You will burn the house down. This is a serious fire risk. The power cables over heat and arc then burn, if the breaker is not right.
Feb 01, 2014 | Dryers
Samsung front load electric dryer not getting hot
There is a thermal sensor type breaker leading to the heating element. They are usually round, about quarter size, with a spade connector on each end. They can be checked by a OHM meter to see if they make a connection from one terminal to the other. There may be more than one. If that checks good then you need to check the heating elements for resistance for one end to the other. If there is no resistance then the element is bad.
Jan 23, 2014 | Samsung Dryers
My Samsung steam dryer dv419ae will not heat? Unplugged and Checked vents still nothing. Whats next
Check your circuit breakers. Dryers can have two circuit breakers (mine does, but not sure if all do). If the one for heat is tripped and the other isn't, it will spin but not heat.
Oct 22, 2013 | Samsung DV419AE Dryer
This is an update to my previous problem with my electric Kenmore Dryer Model #88042700. The dryer appeared to have no power. I had checked the breakers and thought the one for the dryer was on. But it...
There is a reason it's tripping..First I would have the dryer cleaned out it sound like the unit is full of lint and is holding heat also bad ventilation in dryer exhaused. If it's tripping it's electrical
hydeparkappliancerepair.com
Sep 08, 2013 | Kenmore Dryers
Samsung Dryer keeps tripping the circuit breakers
The "professional installer" likely set the pedestal on top of the power cord and damaged it, or the dryer duct has been pinched off causing the dryer to overheat.
Jun 13, 2010 | Samsung DV448AGE Gas Dryer
My dryer will get extremely hot on top after a cycle, then trips the breaker, iv'e checked the vent and it is venting fine
check the amps for youre dryer, then check the amps of youre breakers, you might also want to check the motor if you have never had that problem before
May 10, 2010 | General Electric DVLR223EGWW Dryer
I have a Kenmore (Whirlpool) Elite HE5 Steam front load dryer. Everything seems to work fine except there is absolutely no heat. I checked the breaker, and it wasn't tripped. I checked the lint filter and...
I think I know what the problem is, this actually happened on a dryer I repaired at one point. Low line voltage to me means that one or more hot leads is not feeding enough voltage to the heating elements (and the heating elements need both hot leads to run) which means the circuit breaker, although on, may be malfunctioning or weakening. You can check this by running your dryer and taking the cover off your circuit panel and checking voltage on the breaker. You should see 110V on each terminal to ground (put leads from one terminal to the grounding bar in the panel). If you see less than 110V on each lead to ground and less that 240V across the terminals it needs to be replaced. (You can get one for under $25.00 depending on brand). NOTE: THE BREAKER USUALLY POPS RIGHT OUT OF THE PANEL, BUT WHEN WORKING IN PANEL TURN MAIN BREAKER OFF TO THE HOUSE AND HAVE SOMEONE HOLD A FLASHLIGHT FOR YOU. IF YOU TOUCH THE LIVE BUSS BAR THAT BREAKER GOES INTO YOU WILL GET SEVERELY HURT. TURNING OFF MAIN BREAKER WILL DISENGAGE THE POWER FROM THE BUSS BARS; NOTE THAT MAIN WIRES ARE STILL POWERED SO BE CAREFUL.
Mar 22, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
I have a hot point dryer, mod#NVLR333ETOWB, i have taked the dryer apart and unpluged the element and checked continuity and i get a solid continuity tone. i put the dryer back together and still the dryer...
Have you checked to make sure that the breaker for it is good? Have you checked to make sure that the wires are tight going to breaker? How old is the house?
Jan 27, 2009 | Hotpoint NVL333EY Electric Dryer
Kenmore dryer
Probably too late to help either of you since this is so old but there are two possibilities (assuming everything else works as normal).
1st
If you really mean the circuit breaker to your house, then the heating element is bad and pulling too many amps. It may be shorting out when it gets hot due to the expansion of metal.
2nd
If you mean a switch on (or in) the dryer then you mean a thermal breaker (or thermal fuse). The most likely problem is that the exhaust vent for the dryer is plugged up with lint either within the dryer itself or in the part that is in your wall and exits someplace outside (could be as far as the roof). When the hot air can't escape the dryer overheats and shuts off to prevent a fire.
Jan 07, 2008 | Kenmore 659 Electric Dryer
Samsung DV438AER Electric Dryer Logo
416 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
