Question about Dolphin Maytronics Advantage
Power supply Keeps blowing fuse. - Dolphin Maytronics Advantage
    President:
  • Dolphin Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It needs a new PCB and/or bridge. You can try to repair it yourself or send it in via mail or courier and we can fix it for you. For repair information or for a quote on parts please contact us thru our site at www.arrowpools.net.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 17, 2010
Crest audio ca4 blowing fuse
There is two possibillities to fuse blown off due to hi current flowing through fuse more than 3amp.because power supply componant like rectifying diode, filter capacitor or regulator ic ,regulator transistor shall be short circuited.
if you are tech......just remove amp. supply.from main power supply...try with another fuse........if fuse ok, fault is amp side, or if fuse blow off ...power side problem just....maximum fault comming on varistor ,diode, filter capacitor, .........
if you are not tech......... give to local authorised tech.......
Feb 04, 2018 | Crest Audio CA4 Amplifier Amplifier
No power or light, plus power supply keeps blowing fuse
you have a short most likely on the power supply but could be on the mainboard, inverter board, av/input board. The T-con board is fused and should blow its fuse before blowing the fuse on the power supply. I'm going with a faulty power supply, most likely a shorted Mosfet.
Sep 24, 2011 | Philips Magnavox 42MF521D/37 Television
The fuse keeps blowing in my amp, changed the fuse several times but just keeps blowing!!!
You have an overload in either the power supply section or Main amp section. Culprits in the power supply are the transformer, the Large Capacitors, rectifier, voltage regulator.
In the Main amp anything on the heat sink.
Look carefully for burnt or damaged parts. If there's more than one fuse, follow the path of the one that is blowing it might lead you to the suspect.
Dec 15, 2009 | Alesis RA-150 Amplifier
Blows fuse when turned on
this is a normal behavior if one of the power supply transistors have blown. take the unit to an enlectronics repair. they can either change the transistors affected (usually more than one) or replace the power supply board.
May 29, 2009 | Sansui DTV3200 32" TV
Monitor fuse keeps blowing
There is definately a shorted component that causes the fuse to blow. Nomaly the ceremic capacitors are the cause of the problem. Check to see if there is visiual dark or burnt ceremic caps with label sameting like this "SCK 083" near the fuse area and change it. Hope it helps,cheers.
Jan 21, 2009 | Computers & Internet
Blows 4 amp fuse inside tv
the poer supply faulty. Isolate Horizontal output stage from the power supply and connect dummy load (like normal bulb same wattage as TV ) and test. before that pls check all component in power supply and replace and burnt parts spacialy diodes caps and power regulater ic as well
Jan 15, 2009 | Televison & Video
KEEPS BLOWING SOUND FUSE
When you refer to the "sound fuses" are you referring to the speaker protection fuses or the power supply fuses?
Dan
Jan 14, 2009 | Audio Players & Recorders
Blowing fuses in power supply
One thing to check, would be the filter capacitator that is on the front circuit board. They are known to become shorted. The cap is fairly large, and may be mounted on the side of the circuit board that faces the front panel. Clip one lead, and apply power. If the fuse does not blow, then that is it. A second possible component, is the polarity protection diode, that is near the power jack, next to the fuse. If it is shorted, then the fuse will blow every time.
Aug 21, 2008 | Optics
The fuse keeps blowing every time i put new one in it
If there is short circuit in power supply, fuse will blow itself to disconnect the circuit just to avoid fire or further damage in unit. Please check power supply of your unit.
Aug 19, 2008 | Audio Players & Recorders
Dolphin Maytronics  Advantage Logo
297 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Marvin
Marvin
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
