Question about Whirlpool ED2FHGX Side by Side Refrigerator
NEED TO REMOVE DOOR HANDLES - Whirlpool ED2FHGX Side by Side Refrigerator
    Genius:
  • 1,417 Answers
this are the instruction to follow below
1.Check out how the door panels are attached to the car. Most panels usescrews and bolts but others have snap-in fittings. Gather all the toolsyou need for removing the door panels. If the panel is attached withscrews and bolts, you need a screwdriver or ratchet and socket. Cardoor panels with snap-in fittings are easily removed with a flatheadscrewdriver.
2Locate where the screws and bolts are before starting. These areusually found in the arm rest area, along the bottom or sometimes nearthe door lights.
3 Roll down the car door window. Begin removing all screws and bolts thathold the door panel onto the car. If your car has snap-in fittings, prygently on the bottom corner of the door panel until the fittings popout.
4.Remove the power window control panel if your car has power windows.The control panel should pry out easily, and then you unplug the wiringharness from the back and place it to the side.
5Use an L pick and flashlight when locating a manual window crank. Lookbehind the window crank and slide the pick under the edge of the metalclip that holds the crank in place.
.Remove the clip and pull the crankoff.Remove the door handle by unscrewing the small screw located in thecenter. Gently pull the door handle out until you see the back of thehandle and unclip the rod from the door handle. This should remove thehandle unless the handle and door lock are attached, then you justunclip the rod from the lock and remove them both together.
7.Unscrew the cap off rear upper corner doorpanel locks. These don't have a rod attaching them to the handle andunscrew separately from the door handle.
8.Pop the door panel off after you've removed everything. Gently pry onthe bottom edge of the door panel until it releases. Pull out and up tocompletely remove the door panel.
please do all this instruction with care thank and
thanks for using fixya.
  • Step 8 Pop t
  • Read more: How to Remove Car Door Panels | eHow.com http://www.ehow.com/how_2164577_remove-car-door-panelsremove-car-door-panels.html#ixzz0vxRgii6t
    Posted on Aug 07, 2010
    Remove interior door panel 2002 Chevy tracker
    No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
    Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
    Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
    Disconnect the window switch electrical connector, if equipped.
    Remove the door trim panel (3) from the vehicle.
    Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
    Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
    Remove the window regulator handle (1), if equipped.
    Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
    Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
    Remove the outside rearview mirror opening cover (2).
    Remove the screw which secures the front side door pull handle (4).
    Removal Procedure
    Remove the screw which secures the front side door inside handle (1).
    Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
    Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
    Remove the inside handle (1) from the vehicle.
    Check out youtube video showing how to do it !
    How To Remove Install Front Door Panel Suzuki XL 7
    Jun 10, 2017 | Cars & Trucks
    I need written instructions on how to replace a outside driver side door handle for an 06 ford focus
    Close/wind up the window. Remove the inside door panel. Be careful with power window switch and door speaker wiring connectors. Disconnect them before pulling the door panel away. Remove any plastic covers that may be glued to the door. Have a look at the door handle from inside the door. You will have some idea as to how to remove it. Usually door handles are secured by screws from the inside. Locate and remove them. Remove linkages to the door handle then pull handle form outside.
    Jul 20, 2014 | 2006 Ford Focus
    How do i remove the fridgerator door handle
    HOW TO REMOVE DOOR HANDLES (LFX25960
    To move refrigerator through a house door, it may be necessary to remove the refrigerator door handles.
    1. Removing Refrigerator Handle
    Grasp the handle tightly with both hands and slide the handle up (this may require some force).
    The keyhole slots on the back of the handle allow the handle to separate from the mounting screws.
    CAUTION:The handle could be damaged if you hit it with a hammer while removing or attaching.
    CAUTION:When you assemble or disassemble handle, you must push or pull with reasonable force.
    2. Removing Freezer Drawer Handle
    Press the handle against door first.
    Grasp the handle tightly with both hands and slide the handle to right (this may require some force).
    If you need help:
    http://us.lge.com/download/product/file/1000003873/LFX25960_LFX21960owners.pdf
    Apr 29, 2011 | LG LFX25960ST Stainless Steel French Door...
    I need to replce the drivers side mirror. Just seeking instructions on how to.
    Remove front door handle bezel screw cover Remove inside handle bezel screw Remove inside handle bezel Lift upward on the rear of the front door inside handle bezel Disconnect electrical connector Remove handle screw cover
    Remove handle screw Remove door trim panel upper screw Remove door trim panel lower screw Remove door trim panel (pull the door trim panel outward to release the pin-type retainers)Remove front door sail panel
    Disconnect mirror electrical connector Remove 3 exterior mirror nuts and exterior mirror
    Mar 07, 2011 | 2009 Ford Fusion
    Replacing the outside doop handle
    You will need to remove the inside door panel to change the outside door handle...remember to raise the window to allow more access...the door handle bolts on the inside are 10 mm...To remove the inside door panel...you will need to remove the armrest first...screws are receased on door handle...Hope this helps.
    Feb 04, 2011 | Chevrolet S 10 Cars & Trucks
    Replacing driver side door handle
    First, ya gotta remove the interior door panel....
    Door Panel
    1. Fully lower the door glass.
    2. Remove the arm rest, door lock knob and inside door handle escutcheon.
    3. Remove the regulator handle.
    4. Gently pry the door panel away from the door.
    5. Installation is the reverse of removal. Install the regulator handle (correct position) with the door glass closed.
    Next you'll need a small ratchet and extenstion with socket...or a socket driver (like a screwdriver but holds a socket). Remove the two nuts attaching the handle to the door. Use a long thin flat screwdriver and pop loose the clip attaching the rod to the lock mechanism..
    Manuever the handle off the door and then install in reverse order.
    May 28, 2010 | 1987 Nissan Pickup
    How do i remove door outside door handle on q7
    On the inside trim, you can remove screws (these screws may be covered by filler pieces or may be visible, or they may require you pry a plastic piece off that covers the screws) that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can disconnect the linkage connecting to the outer handle and remove the bolts securing the outer handle on
    Nov 05, 2009 | 2007 Audi Q7 4.2 FSI
    I have a susuki forenza and I need to replace the driver's side door handle. I already have the new part (door handle).
    On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can remove the inner door handle and replace with new one. If it's your outer door handle, pull back the weather seal and disconnect the linkage to the outer door handle and then remove the bolts securing the outer handle to the door
    Oct 23, 2009 | 2006 Suzuki Forenza
    Replace exterior door handle on a jeep commander
    On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Pull back the weather seal and disconnect the linkage to the outer door handle and then remove the bolts securing the outer handle to the door
    Oct 23, 2009 | 2006 Jeep Commander
    Replace left front door outside handle pot metal tip broke off
    SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual REMOVAL AND INSTALLATION Exterior Front Door Handle Removal and Installation
    1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
    1. Position the watershield aside.
    1. NOTE: The tie strap does not need to be reinstalled.
      If equipped, remove the tie strap from the anti-theft guard.
    1. Remove the screws and position the anti-theft guard aside.
    1. Release the clip and disconnect the exterior door handle actuating rod.
    1. Remove the anti-theft guard.
    1. Remove the exterior door handle screw.
    1. Remove the exterior handle actuating rod.
    1. Remove the exterior door handle lock cylinder cover.
    1. Remove the exterior door handle.
    Apr 25, 2009 | 2001 Ford Escape
    Whirlpool ED2FHGX Side by Side Refrigerator Logo
    490 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
