Question about Roland MMP-2 2-Channel Amplifier
MMP2 seems to have no voltage selector. Manual states power as 230, 240, 110v. I am reluctant to plug my US 110v unit into UK 230v mains. Would appreciate any info?
  • Al-4 Aug 10, 2010
    Seem to have solved problem by call to Roland UK techies. It apparently uses same system as VS series and senses incoming voltage then automatically switches to correct voltage. Assured me perfectly safe. I don't know why they don't make this terrific facility more widely known. Hope this is of help to others.
    Genius:
  • 1,175 Answers
Check the manual..It's on the Roland site
In that unit , it's most likely an auto-switching power supply ie; universal 105 - 230 volts AC 50-60 hz
Posted on Aug 17, 2010
Testimonial: "Many thanks. Confirms what I suspected. Just can't figure why they mark them with local voltage. Maybe to test our nerves! "
HI I HAVE A DIAMOND DVD PLAYER WITH TWO WIRES CONNECT TO THE PLUG WHICH CAME ORGIGNALLY. SHOULD I CONNECT TO THE WALL SOCKET
I would need more info as to what you refer to?
I can only think you refer to its mains lead which mostly are black and may have a "strange type of moulded plug" on its end that is not a 13 amp UK type.
It should come from the back which will have markings near it regarding mains voltage, If NOT then show it to an electrician first to be safe.
If it has voltage indications of around 220v 230v but a strange plug you can buy adapters to convert to UK, or maybe if you can, though I think there are laws now which prohibit this in some way, remove it and fit a UK plug with a 3 Amp fuse
Hope this helps........
Jun 01, 2016 | Televison & Video
What is psu?
Power supply unit computer
A power supply unit (PSU) converts main AC to low-voltage regulated DC power for the internal components of a computer. Modern personal computers universally use a switched mode power supply. Some power supplies have a manual selector for input voltage, while others automatically adapt to the supply voltage.
Apr 25, 2014 | HP Pavilion a1253w Notebook
What is the power input voltage required to operate the phonic 1805x audio mixer? is this an AC, or DC input? unit missing power supply and needs to be bench tested for possible future use. no manual...
i have seen the manual. most mixers use ac mains supply with smps inside with +48V for phantom and ur mixer is one of those. u will see a three pin mains connector at the back. but phonic made these mixers for different countries. for us/canada 110~120Vac/60Hz - for uk/australia  230~240Vac/50Hz, europe/ asia 220~230Vac/50Hz.
Look for these or a voltage selector near the power input terminal. if u do not find any of these one sure way of finding which mains supply u should use is to open the case and look at the biggest rectifier filter capacitor on the smps board. 110~120V supply will have capacitors working voltage around 250Vdc and for the others around 400Vdc working voltage. (eg 1000uF, 250V or 1000uF, 400V)
so depending on the DC working voltage of the filter capacitor and country u either step up or step down the mains supply.
18Vac supply will never work.!
the rated mains voltage sometimes are printed on the smps board itself. Hope this helps.
Mar 13, 2010 | Electronics - Others
What do I need to use my Touchsmart tx2 in France. Do I need an adapter or transformer or both
You live in the US, right?
First check the voltage rating on your power supply / charger's primary voltage range. If it states around 110V only, then you need a transformer from 230V to 110V with an euopean plug. Make sure it's a real transformer (rather heavy, rated at ~100VA will be OK), and not a lightweight high-power adaptor, used for lamps, pressing irons, heaters and similar appliances.
If on your charger it states something like "90-240V", then it will cope with the standard european voltage of 230V, and the only thing you need is a travel adapter that will have an european plug on one side and an american socket on the other.
Oct 25, 2009 | HP TouchSmart tx2-1270us Tablet PC
MAYTAG DE713 dryer Voltage Option
Yes, the 120 -240 is the range in which your dryer can operate. Many times the standard for Europe is 230 and the 240 allows for power surges that are common.
Aug 30, 2009 | Dryers
Samsung LA32R71B
first of all what area are you living in in Philippines 220v as there is voltage rating differences in Dubai
Djibouti 220v Dominica 230v Dominican Republic 120v Dubai 230v
64 other voltages. 50Hz
the board will be set for country of origin, this could mean the power board can be getting more than the ratings need, there will be voltage regulating chips on the power board, main voltage can handed depending on the chip installed up to 600 volts but the other parts cannot handle low voltage or high voltage, this could mean a spike in voltage may not blow but it may weaken the voltage out. i.e capacitors- voltage regulators or even diodes. these have to be checked.
Jun 26, 2017 | Samsung LN-R328W 32 in. HD-Ready LCD...
Power on but nothing else
My DVD22 did exactly the same. The solution mentioned by shelompidid not apply to me since my model already had the fix factory fitted.
The other problem mentioned on page 21 of the service manual did the trick for me, although the complaint does not seem to be directly relavant:
"Complaint: Will Not Read Disc; Other Functions May Be Disabled
See h/k service bulletins HK2004-03 and HK2005-02, as the issues covered there involve similar
symptoms.
Probable Cause: EC19 and EC20 (1000μf 16v capacitors) may be defective in the power supply. This can be checked by measuring the +3.3v and +5v voltages that are associated with EC19, 20 to see if they are low (more than 0.1v low). The SPMS output voltages are marked on the PCB adjacent to the large 13 pin header. While there is only one 3.3v pin, there are several +5v pins, and care should be taken to measure the correct one(s), which are either two +5v pins approximately in the center of the header.
I could actually see on the power supply board that these two caps were damaged, although they were not completely popped. An additional cap which was damaged on my board was EC4.
When I measured the voltages the middle D +5V was reading about 4,6V. I did not expect a problem until I read the statement above on page 21 stating it should not be low by more than 0,1V. My A+14 and A-14 voltages also read about +/-17 to +/-18V.
I replaced all three caps: EC4, EC19 and EC20 with 25V caps instead of 16V caps. The voltage for D +5V now read exactly 5,01V! The A+/-14 read +/-16V (some improvement).
My unit is operating fine after replacing these 3 caps! I suspect that the damage to the caps could have been spikes on the AC suppy some stage, maybe due to lightning. Pretty amazing that only the power supply have damage and not the main pcb.
May 06, 2008 | Harman Kardon DVD-22 DVD Player
Power supply.
of course yes, the purpose of the converter is to convert the power output to desired voltage.
Feb 05, 2008 | Logitech Z-2300 Computer Speakers
No power to decks
sorry to say but you may have destroyed the units. USA uses 110volt. Uk is 240volts. There may be circuit protectors, pico fuses, internal fuses, and transformer fuses that have failed. replacing them first is the first approach to getting them going again. An adapter plug is not what you need. You require a step-down transformer to reduce the voltage supplies to 110volts. Check on the units also. There may be a voltage selector switch that you can select the right voltage for the UK. Be careful with how you go. Mains voltage kills. If you are not sure then please go to a tech and have them check the decks over for you. Good luck
Jan 31, 2008 | Audio Players & Recorders
Roland MMP-2 2-Channel Amplifier Logo
113 people viewed this question
Top Roland Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Joseph Mueller
Joseph Mueller
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
