Where can i locate the exit filter to see if it is clogged? the hose seems clear i think could it be the pump : the washer is only 4 yrs old and used only once everyother week. 2 people here> lid latch appears ok and i think how would i know if its not and would it have washed at beginning.
To check the lid switch set it on spin. Should spin with lid closed & not spin with lid open. What is your problem ? (not filling ) ( not agitating ) ( not draining) ( not spinning ) it won't have an exit filter.
If the lid switch is ok it should agitate drain & spin .. The lid switch could stop agitate on some & not on others. If it is not draining it could be the pump. Sometimes a sock or something small can go down the drain and get in the pump & stop it up then it won't drain
like it should. Always say what the problem is like agitate or spin.
Hope this helps
SOURCE: F21 error
Peace Friend,
ngfam1 At your service!
NO GOD FOR BID DO NOT USE DRAIN OPENER IN AN APPLIANCE!
First try this, unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
SOURCE: Not switching from rinse to drain cycle
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Select "Search by Part Number" and enter the following part numbers: The lid switch is part #3949238 and the lid strike is part #350733. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
SOURCE: how to install lid switch
The symptom of a washer that fills normally, but stops suddenly and will not drain is commonly caused by a lid switch malfunction.
The following link explains how to install a lid switch:
If this is just a matter of reinstalling a switch that has come loose, a new switch may not be required. Inspect to ensure the mounting screws, switch casing, or switch lever are not broken. Make sure the mounting screws are tight. NOTE: You do not have to drain the washer to replace the lid switch. With the switch replaced, the washer will drain on its own. This will save anyone the trouble of having to bail. If you have questions, please let me know. I hope this helps.
SOURCE: How to bypass a lid switch on a Kenmore 90 series washer?
I took a small screw driver and inserted it into the hole, pushing down gently, further then the little plastic arm on the lid could reach. It continued on with the cycle so I knew that was the problem. I took a plastic sheet rock anchor,(the kind that you drill a small hole in wall then slip it in, and when a screw is inserted it expands behind the sheet rock and will not pull out) and slipped it over the little plastic arm on the lid (it pushed the switch a little further in, which enabled me to use until I could replace. The I went to youtube and they have lots of video's on how to take the cover off and fix.
SOURCE: HE2 Plus front load washer keeps showing F21 error
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris. This solution will fix your problem.
