Question about GE Energy Star WCVH6260F Front Load Washer
GE Front Loader will not despense Fabric Softener
We had a problem with our washer not runnng the full cycle a few months ago, and we had a tech. come out and replace the whole curcit board! That didn't even fix the problem, my husband figured out that he just had to clean the catch tray.But when the tech. came to replace the computer, he reprogramed the system, and ever since then our washer will not despense the fabric softener. It despenses the soap just fine, but the fabric softener is still thhere at the end of the cycle. Could this be due to reprograming the washer wrong? HELP!!
  • slf24 Jun 28, 2008
    Same problem won't despense softener
We checked the cold water line that goes into the washer, it had some pretty nasty stuff in it, and once we cleaned it out, and soaked it in CLR, it cleared up the line. Once we reattached it and ran a cycle, it went great. I am assuming with the line being clogged it didn't have enough water pressure to flush out the fabric softener.
Posted on Apr 29, 2008
Fabric softeneer despenser has water in it. We have not used the despenser. Have a whirlpool cabrio top loader
Had one where the softener dispenser had all kinds of dried up crud from the softener which caused the water to collect there instead of drain down. It actually looked like wax, after cleaning it out the water problem went away.
Apr 20, 2011 | Whirlpool GSC9455 Top Load Washer
Fabric softener does not despense
may be the dialer is not working to that function
Dec 10, 2007 | Samsung WF337AA Front Load Washer
I own the Whirlpool duet set with the front loading washer. The clothes comeout with a bad smell. I was told that the washer probably needed to be cleaned. How is this done, and what makes it happen?
Using the wrong kind of detergent in your fancy front loader is a great way to grunge up your washer and impart some oder onto your clothes. And it accelerates the mechanical deterioration of your washer.
2. Using too much fabric softener and/or detergent.
Liquid fabric softener does not break down very well in cold water and the residue collects on the outer tub and basket along with the lint left from the wash. We professionals refer to this accumulated as grunge. Once formed, this grunge collects ever more additional soap, dirt, grease, human waste, mites, , parasites... and then some really bad stuff.
As it turns out, this grunge makes a perfect substrate for microbial life forms. Over some time- not very much time in warmer climates- those little bacterial colonies build up lots of microbial sewage, just like we do until one day you open the door to the washer
Using too much fabric softener will waterproof your clothes. How clean do you think your clothes will get if they repel water inside the washing machine?
3. Doing all your wash loads in cold water only.
Detergents don't dissolve as well in cold water. As a result, cold water washes leave behind more grunge. So... do an occasional wash in hot water. OK, maybe more than occasional. Like, I hope you at least wash your skivvies in hot water.
4. Leaving clothes in the washer at the end of the cycle.
Front loaders don't have as much access to open air as top load machines. Consequently, leaving clothes in the washer for more than eight hours will increase mold and mildew build up.
1. Add one additional gallon of hot water to the unit before sending it into a hot wash. This will raise the water level high enough to remove the Grunge Hiding Behind the Basket
2. Same as 1 but with bleach added to all dispensers. Clean the fabric softener cup with a rag first (bleach will not break up fabric softener since it is introduced in the rinse cycle with the fabric softener).
3. Same as1 and 2 but with a cap full of pine cleaner added to the wash water (NOT the dispenser). Add some old rags (they don`t need to be dirty) and select the extra rinse cycle. The wash action will help remove the accumulated grunge from the components
Once again, make sure you're only using high efficiency (HE) detergents in your front loader.
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
My GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Aug 09, 2009 | GE WSXH208A Front Load Washer
Odors on the clothes after washing in Maytag front loader
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
Oct 23, 2008 | Maytag EPIC MFW9700S Front Load Washer
My front loader Bosch washing machine is not draining in the fabric softener section.
Make sure it is the fabric softener that is not being added. Try running w/o fabric softener and see if the tray is still full. The reason I am asking is that after I run my washer the fabric softener tray is full, with water, not softener. The factory tells me it is because the water fill nozzles have realigned and overspray into the softener tray. Not a big problem, since my system is under warranty I am having them fix the nozzles and then I will know how to redirect.
If it is the softener that is not being added then check to make sure the line is not clogged. You can lift out the bleach / softener try and check for cloggs.
Aug 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Machine will not use fabric softener
the despenser has a servo motor on the top of the despenser, you have to remove the top of the washer to get to it, it is on the left side of the unit looking form the forunt, check the motor woth a vom meert on resistance, if you get a reading, meter needle moving twards the right the motor probally is good, if no eter movement the the motor is bad
if you have meter movement after checking the motor then the control board is bad
Apr 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
341 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
