I am looking to buy two uv lamps for a micromark MM3811 Fly Killer. The part number I got last year and was given in the litrature that came with the unit is MM7188
  • 3 Answers
If you can find a supplier, I'd love to know. The only supplier I could find was charging double the price of the fly killer. I think these things are a bit of a disposable item.
Posted on Jul 25, 2012
Recently moved into a property with an alarm. MICROMARK TN 0045903J, it requires batteries. Looking for a user manual.
Maybe the reference it is not correct, here are some examples of Micromark alarms references:
MM9412
MM9492
Try to find the correct reference or model number, contact me and I will help you
Oct 26, 2017 | Home Security
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
www.petco.com/.../Sealand-Replacement-Bulb-for-Green-Killing-...
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
https://www.norlandprod.com/lightsourc.html
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
Dec 10, 2015 | Honeywell Air Purifiers
How long does termite/carp ant killer last for?
when they are done properly, termite/ antkiller treatments should last for up to 5 years.
Jul 17, 2012 | Bonide Termite/Carp. Ant Killer Conc. 1...
Never bought a Lamp for my Mitstu before is there a differance between Generic and another brand?
Buy cheap and get cheap----the originals last average of 2000 hours and generic less than half that----considering the real drop in price on the OEM ones you will get what you spend for it.
Google the model number with "Lamp" with housing---a bulb alone requires you to take that housing apart and an original with the housing is a slide in unit---also when buy look at the warranty--some cheap ones are 90 days and better ones from 6 months up to one year---no bargain is a bargain if you have to replace it a few times in a year.
Jun 06, 2012 | Mitsubishi WD-62531 Projection Television
The UV-visible spectrophotometer(Cary 100 Bio, Varian company) in our lab is now showing faulty error while starting the instruments. It says Error Code: 9:9330SEQ:E9330, chopper not upto speed. Where to...
May be that your deuterium lamp for UV or possibly tungsten lamp is out or misaligned. Ran into something similar several years ago. The UV lamp initially ignited but shut down a short time later ( less than a minute) since there was not enough intensity being detected. The error message was similar.
Sep 30, 2010 | Kitchen Ranges
Where can i get instructions for a Micromark MM52121 Tea Express?
Hi, did you find any as I'm in the same boat and as Micromark have folded can't find instructions anywhere
Thanks
Dec 28, 2009 | Coffee Makers & Espresso Machines
I have a micromark mm23244 alarm and have lost the instrustons, need the reset code so i can use it as some1 tryed to get in the house last night tyx
You can find most user instruction manuals at, www.managemyhome.com.
You will need the model number off the unit. The search box is on the right side of the page.
Jul 05, 2009 | Micromark England Microcooler Plus Compact...
Fresh air flashes
This looks like a control board error. It needs to come in for repair. be careful not to turn it on, the RCI cell ( the blue light in the back) will stop working if it is switched off and on fast.
Call the company 1-800-989-2299 and get an RMA number. If you are under three years, you are still under warranty.
Dutch
Mar 28, 2009 | Ecoquest Fresh Air Air Purifier
Projection lamp burn out
well look at this,, I use many projectors due to my work with artist and my bussiness in wedding and happybirdays,I have to chage those expensive lamp frecuenly. a cople of time the lamp fuse off rapily in short time and the store is ok no buddies warrant electric or electronic parts so we the custumerpay for the in line manufacture bad parts so nothing to do buy another one and thats all you can do but clean the soket and allway look for crack or weare parts in the socket I use to inspect everything in the lamp system specialy the socket and clean the contatc were you conect the lamp with a very thinn sharper tool if you suspec change the lamp socket they always work at verry high temperature ....good luck and rate me
Jan 05, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
