Question about LG VOYAGER VX10000 Cellular Phone
Im trying to charger my lg voyager on my computer through a usb charger but the screen wont turn on!?
  • 677 Answers
WON'T TURN ON
Hi,when a phone does not come on, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery for longer hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Posted on Aug 07, 2010
LG Optimus L9 Screen blacks when charger/usb-to-computer cable plugged in.
sounds like you have a usb cable for charging only.You need a "2 way " usb cable,the kind used to transfer music and pictures to and from phone to computer.These one way cables are usually used in mobile chargering,as you don`t need to transfer things,just charge.Or you got wrong cable for your phone.
Mar 02, 2014 | LG Optimus Black Smartphone
LG xv10000 wont turn on I get a battery required message but the battery is in
Hi Orrin,
Is your battery flat?
Please try plug your charger then turn on the phone. If your phone works, the battery is out service and need replacement with new one.
Regards
Oct 12, 2011 | LG VOYAGER VX10000 Cellular Phone
Ebay phone wont charge
while holding phone upright in you hand look on the side in the lower left corner - open the "tab" This is where you charge the phone with both a wall outlet & a car charger.
Mar 02, 2010 | LG CHOCOLATE VX8500 Cellular Phone
How do i download my music and pictures from my lg voyager to my computer
When you bought the Voyager, you should have gotten a USB cable to connect the Voyager to a computer. If not, you'll need to purchase one. NOTE: the USB cable needed has a standard USB connector on one end, but the other connector has to fit the Voyager (same place the charger plugs in at). Verizon sells the USB cords for the Voyager.
Your other choice is to get a MicroSD memory card, put it in the Voyager (place on the side to insert it), then put your music on pictures on the card, then take out the card and put it in your computers memory card reader, if it has one.
Feb 07, 2010 | LG enV VX9900 Cellular Phone
Why won't my phone charge?
There could be a few reasons:
1. The charger wire is damaged/has a broken wire
2. There is no power to the receptacle your charger is plugged in to.
3. If using a vehicle charger, either the fuse in the charger or in your vehicles fuse box is blown
4. If using a USB cable to charge the USB port on your computer may be not completely connected.
5. There may be a problem with your phone or battery.
Sep 27, 2009 | LG VOYAGER VX10000 Cellular Phone
Every time i try to connect my lg voyager to get music or pictures my computer says that a usb has malfunction and does not detect it? whats wrong it worked befor?
First thing you should do is download the latest driver for it. That is the number one reason a device wont be detected by PC. The second reason is a bad cable or loose connection
Aug 07, 2009 | LG Car Charger For VX8700, VX8800 Venus,...
Cant use voyager while its charging
I have just started having the same problem. At first it wouldn't allow me to hear when it was plugged in to an AC outlet, but it would be ok if I was charging through either the car charger or USB plug. Now it doesn't work no matter what type of device I charge with. I too need a solution.
Jul 08, 2009 | LG VOYAGER VX10000 Cellular Phone
LG View Wont Turn on, stuck on start up screen.
There may be a problem with the charger, as this is what happened to me. If you bought the phone abroad and only received a 2-pin charger, it means that this has messed up the data on your phone. Because the chargers abroad can only hold up to 120volt, so if you have  plugged it into a shaver socket or into a two-pin converter which gives you a 3-pin, it will still mess up your phone. I recommend you take it to a shop to fix. It cost me £25 to fix, but it's working fine now.
Apr 16, 2009 | LG KU990 Viewty
Wont turn on
my pc no reconoce the driver the usb vx6000
Jun 10, 2008 | LG C2000 Cellular Phone
LG VOYAGER VX10000 Cellular Phone Logo
93 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
