Question about Air Tools & Compressors
New Holland Tractor TN75...History: AC won't cool..added freon... too much head pressure causes the belts to slip...lower high side pressure still will not coool; changed the dryer got 134a to overcome the off pressure switch ; now the compressor will not **** the freon on the lowside?? freon introduced on the high side to release the pressure swich now shows the low side pressure at 100 # and the low side will not **** more freon...only one and 1/2 cans put in... and cannot get more in... high side shows about 50 #??? I have opened the high side to release air, but I am stumped..
2 Suggested Answers
  • 1388 Answers
SOURCE: pressure switch out of adjustment
Before you adjust the perssure switch, make sure that the intank check valve is not leaking pressure back to the pressure switch after it cuts off at 140psi. The check valve should hold pressure at 140psi. Follow the discharge airline to the tank to find the checkvalve (either chrome or brass with large cap). To check for leaking valve, run compressor till shut-off at 140, then unplug the compressor from wall and remove the 1/4 air fitting at the checkvalve and check for leak. If leaking, replace valve and leave the pressure switch at present setting. You should be good to go. Good Luck with your repair and email if you have questions.
Posted on Apr 04, 2009
On my 2006 ac works good when engine is cool, in stop & go traffic it blows hot air & head pressure gets high in ac, car temp is ok what's wrong
How do you know head pressure is high? Do you have an auxiliary electric cooling fan that is not coming on in this situation? It should be in front of the AC condensing coil. There may be a switch tied to the system that is bad. This switch is sometimes activated by the pressure in the high-pressure line to the condenser coil. If there is not enough freon (134a) the pressure will not be high enough to activate the cooling fan switch. I recently added one can to my system and it made the fan run whereas it did not before adding the freon.
Jul 05, 2015 | AC Cars & Trucks
2008 legacy air conditioner was blowing cool air but not cold I added one can 134a on low pressure side with motor running ac on high cold now it only blows hot air
I highly recommend that you get it checked by a professional. You may have a restriction in your system, or the system is way overcharged. In either of these cases, the possibility of high pressure causing lines or hoses to burst and possible severe damage to your vehicle, like a destroyed compressor, is very likely.
Also, check the can that you added freon from. Many of the small cans of freon sold at the local parts retailers have several ounces of "oil charge" in them. Many times, when these cans are used to fill the system, the system ends up saturated with too much oil, which can also cause dangerously high head pressures, which can result in severe damage to your vehicle. In these cases, the system must be evacuated and flushed out to reduce the amount of oil in the system before it will cool properly.
Jun 14, 2012 | 1995 Subaru Legacy
My daughter's 2000 Dodge Neon's air conditioner wasn't cooling very sell so she took it in to have freon added. The shop drained all the freon out and then tried to add new freon but none will go into the...
you need the compressor running to get freon into the system
using gauges on a manifold you allow the compressor to suck the gas in to the system until you get a pressure reading at the high side gauge
That is the correct amount of gas for the system
take it to an accredited ac specialist shop to have the job done properly
May 20, 2017 | 2000 Dodge Neon
AC comes on, then shuts down before car is cooled. Compressor activates and blows cool air for about 15 seconds then shuts down.
Low on R134a, you need to have the system recharged. Try to stay away from the do it your self kit that most Auto Parts store carry.
Below are normal car AC pressure readings with 134A
Normal readings on high and low side with AC OFF (static pressure) – Depends on outside temperature, but normally is between 80-105 PSI
Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s – Ranges from 25-35 PSI
Normal high side reading ranges from 200-350 PSI
Don’t assume that if adding little Freon is good that adding a lot is better! Overcharging just a little can decrease the performance of the system and possibly damage the compressor.
Thank you for using fixya and good luck.
http://www.freeautomechanic.com/airconditioning.html
Jun 12, 2010 | 1998 Cadillac Eldorado
I have a 1994 chevy c1500 with a 305 motor. when i turn on the A/C the clutch engages/disengages continuously but no cold air. Any ideas?
Your A/C system may be running low on R134a.
To diagnose problems, an A/C manifold gauge set is needed to read high and low side pressure readings. Avoid adding refrigerant with a simple charging kit like the ones sold at parts stores. Don’t add any stop leak, this can cause problems in the compressor, expansion valve or condenser.
First, on a 134A system the high and low side service ports are different sizes. AC gauge sets have color coded hoses, the blue color coded hose has a connection that fits on the low side service port and the red hose has a connection that will only fit onto the high side. The yellow hose won’t hook up to anything if just checking the readings; it can be used to connect to a vacuum pump or attached to a refrigerant can or tank.
Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s – Ranges from 25-35 PSI – Note that on many Chrysler products a normal reading on the low side may be 15-25 PSI
With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold – STOP don’t overcharge the system. The only proper way to remove refrigerant is with a AC recovery machine so if this is being done at home I can’t emphasize enough not to over charge the system. And actually the best way to insure the proper charge is in a system, is to use an AC machine to recover the freon and then evacuate and recharge the system with the correct amount. Most cars have the specified amount on a decal under the hood.
Both low and high side readings are lower than normal, this indicates a cars AC system is low on refrigerant and is under-charged.
If both low and high side readings are too high, this indicates an overcharged system – too much refrigerant. This also can indicate that the condenser fan is not working, is too slow or the car is overheating and heat is transferring from the radiator to the condenser.
When the low side goes so low that it’s reading shows it is in a vacuum, the most likely cause is a bad expansion valve or blocked orifice tube. Another possibility is a restricted condenser. Blocked condensers are not as common as they used to be but if a compressor fails and comes apart inside the remnants can end up in the condenser causing it to restrict the flow of refrigerant.
When the compressor clutch is definitely engaged and the low side is high and the high side is low, the most likely cause is that the compressor is failing – it is not pumping sufficiently. Rarely an AC clutch could be slipping but usually this will be accompanied with a squeal or chirp. Also be sure not to overlook the obvious, like a loose belt
Note: The line going from the compressor to the condenser is the discharge line – it is normal for it to be very hot to the touch. The other line going from the drier or accumulator to the compressor is normally colder. The liquid line can be hot up to the point an orifice tube is in place. Just remember that LOW Pressure = COLD and HIGH Pressure = HOT.
If you do want to recharge the system your self, make sure you do not over charge and use the thermometer at the vent and when it's cold enough, turn off the valve from the recharge line and disconnect from the low pressure service port. Good luck
Nov 04, 2009 | 1994 Chevrolet C1500
Ac wont get cold after adding refrigerant
Keep in mind that using an A/C gauge set and seeing BOTH high and low side readings can help in diagnosing the problem when you know what to look for. First, on a 134A system the high and low side service ports are different sizes. AC gauge sets have color coded hoses, the blue color coded hose has a connection that fits on the low side service port and the red hose has a connection that will only fit onto the high side. The yellow hose won’t hook up to anything if just checking the readings; it can be used to connect to a vacuum pump or attached to a refrigerant can or tank.
Normal readings on high and low side with AC OFF (static pressure) - Depends on outside temperature, but normally is between 80-105 PSI Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s - Ranges from 25-35 PSI - Note that on many Chrysler products a normal reading on the low side may be 15-25 PSI Normal high side reading ranges from 200-350 PSI.
Both low and high side readings are lower than normal, this indicates a cars AC system is low on refrigerant and is under-charged. If both low and high side readings are too high, this indicates an overcharged system - too much refrigerant. This also can indicate that the condenser fan is not working, is too slow or the car is overheating and heat is transferring from the radiator to the condenser.
When the compressor clutch is definitely engaged and the low side is high and the high side is low, the most likely cause is that the compressor is failing - it is not pumping sufficiently. Rarely an AC clutch could be slipping but usually this will be accompanied with a squeal or chirp.
Hope this helps. If the compressor did come on and pulled the R134a in to the system, you may still be low or you may be over charged. With out any pressure readings it's had for me to say what is the problem. You could also have a bad orifice tube ( expansion valve) Good luck and hope this helps.
Jul 03, 2009 | 1998 Ford Windstar
Put a pressure guage on ac line it read 90lb
When the compressor clutch is definitely engaged and the low side is high and the high side is low, the most likely cause is that the compressor is failing - it is not pumping sufficiently. Rarely an AC clutch could be slipping but usually this will be accompanied with a squeal or chirp. Also be sure not to overlook the obvious, like a loose belt!
Hope this helps, keep me posted, be glad to help answer any question you may have.
Jul 02, 2009 | 1998 Oldsmobile Intrigue
95 Deville - Low Refridgerant/AC Comp. off
Good luck and hope this helps, keep me posted be glad to answer any question you may have. And yes the A/C system on your car uses R143a and there is a A/C pressure switch along the low pressure line or on the accumulator, it looks like a oil pressure sensor with a two wire lead cliped on it.
Jul 02, 2009 | 1995 Cadillac DeVille
1993 buick century
Heater Control Module
May 31, 2009 | 1993 Buick Century
Compressor will not start.
Usually short cycling means that High side pressure is getting to high (due to not working condenser fan, or dirty condenser coil), or low side pressure is getting too low (might have low level of freon or restriction in sealed system). low side would drop dramatically if indoor blower is not running, so if air is not circulating thru evaporator coil, coil will freeze up and low side would be much lower then normal. Here is video how I found issue with package AC not coming on. Thermostat call for cool, but condenser would not come on, indoor blower runs ok.
Nov 02, 2008 | Ruud UAMB Air Conditioner
Air Tools & Compressors Logo
854 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
