Question about Yamaha RX-V2300 Receiver
Need the remote codes for the RX-V2300 home theater receiver to make a comcast three device turn it on.
2 Suggested Answers
  • 50 Answers
SOURCE: Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
Posted on Jul 06, 2009
How do I code my Yamaha rx-v361 receiver onto my comcast remote control?
To program your remote follow these steps.
1-Turn on the receiver
2-press the "AUX" device key on the remote control
3-Press and hold the "setup" button until the aux key blinks twice, than release the setup button.
4-Enter one of the following codes
30176 or 31176
5-If you entered the code correctly, the AUX key will blink twice and turn off. Now aim the remote at the receiver and press power. If the device turns off, than the code functioned properly. If the receiver does not respond, restart the procedure and enter the other code provided
Good Luck
Jan 05, 2011 | Yamaha Audio Players & Recorders
I have my system set to run with Comcast in a 5 speaker (with powered sub) home theater using HDMI and digital sound. Everything works great except when I forward or rewind on my DVR it's constatntly...
I assume you're using the Comcast remote.
You don't mention which device is changing volume (the receiver or the cable box).
Could it be that the DVR command from the remote is being misinterpreted by the Yamaha as a volume command?
Try blocking the remote eye on the receiver so it is temporarily 'blind' and test the DVR commands to see what happens to the volume.
Jun 07, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha Rx-v365 trying to program remote for
Press and hold "DTV" then, while holding doen DTV, press power and hold for three seconds. Release both buttons and enter your code. The front panel of the receiver will say "remote setup ok" or "NG" (no good) That being said; while you are in the process of finger acrobatics! make sure your remote is pointing in the general direction of the receiver. Yes, it's a pain, however, once your done, the Yamaha remote is a champ! Hope this helps.
Oct 01, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Phillips HTS3566D Home Theater/Comcast DVR 3 Device remote
I have the same problem. The only time that I can get it to work is whenever I turn on the cable box the home theater system turns on too. When I use the DVR it will turn it on too and want to play the CD/DVD. I have a Comcast Motorola DCH3416 DVR box.
Apr 03, 2009 | Philips HTS3544/37 Theater System
Cannot find code for Comcast remote to operate DVD
hi im having the same issue, have u managed to find an answer? rachaelhowell@comcast.net
Dec 04, 2008 | Sony DAV-DX375 System
Comcast on demand custom dvr 3 device codes for sony dvd-hdx576wf
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
Aug 06, 2008 | Audio Players & Recorders
I need device codes for sony DAV HD279w home theater/dvd player controlled by comcast digital cable remote control (none of the codes work in the manual and I tried searching for code and still no luck)...
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
Jul 27, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jul 05, 2008 | Yamaha RX-V1400 Receiver
Comcast remote and need code for a samsung ht-tq85 home theater
http://www.ehow.com/how_2116903_easily-program-comcast-remote-control.html
May 17, 2008 | Televison & Video
CORRECT SETUP CODE FOR RECEIVER
Originally Posted by 3FingeredGlove viewpost.gif We can make this work. You didn't mention which setup code you're using, or explicitly say whether the OK/Select button is red or gray (the manual you're using is for gray), so these are somewhat generic instructions. Should work, though. This will provide a power toggle function to the Power key.
Use red numbers for the red OK/Select button remote, grey numbers for grey button remtoes.
Temporarily assign setup code 30842 or 0842 to AUX
1) Tap AUX
2) Press Setup until 2 blinks
3) Enter 30842 or 0842The remote should blink twice
Assign NEC1 IR protocol device 210, subdevice 108, function number 203 to Power (you don't need to understand these numbers)
1) Press Setup until 2 blinks
2) Enter 994 (2 blinks)
3) Tap Setup
4) Enter 00051
5) Tap Power (not All On)
Assign setup code 30135 or 0135 to AUX (this is NEC1, 210.109)
1) Tap AUX
3) Enter 30135 or 0135
Nov 15, 2007 | Onkyo HT-SR800 System
Yamaha RX-V2300 Receiver Logo
147 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
