Please provide the correct code for the Advent HT2751A television. The remote for the unit itself is broken and I want to use my (Motorola) cable box remote in its place
  • abtatum Aug 07, 2010
    I appreciate the information that I could buy a universal remote; this is something of which I'm aware. What I'd like is which code to try with this television (Advent HT2751A), to avoid a possibly expensive purchase.
  • 11,800 Answers
Unfortunately your remote doesn't officially support your tv. The only thing you can do is to check all the other codes, maybe one of them will match. If none will then you need a new replacement remote for the tv.
http://www.newremotecontrol.com/Mfrs/OtherBrands/Def/dyn_part_data.php?catnum=301-CT3251-010C
Posted on Aug 07, 2010
  • 3,866 Answers
Not all motoral cable box remotes are advanced enought to handle the code for this tv, let alone be a replacment remote, allow me to share with you a diffrent solution because this will not work for all fuctions of the tv and that is www.remotes.com they sale remotes that wil work with your box and your tv, there are also other advanced solutions like Logitech Harmony remotes that will work with everything that has a ir sensor respecitvly.
Thanks for your question I hope our answer meets or exceeds your expectations please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Through Amazon a Brookstone's "Jumbo Universal Remote" was delivered - there is no identification of who manufactures this remote. We need to have it control an AT&T-California cable box which was...
I happen to be a Jumbo Universal remote Expert here at Fixya, so I hope I can help. It is possible that this remote just won't run your Motorola cable box, but I wouldn't give up until I had tried the codes from the list in the manual, as well as run through the auto-setup feature of the remote for CBL and for SAT, where it just tries all the cable box codes one at a time.
I was able to find a working motorola codes for an Innovage Jumbo Remote, a three digit code remote you might as well try: 051.
You have probably tried the codes for Motorola (031) and GI (000, 032) from the manual using these steps:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device. (000, 031 & 032 for example)
3. Press and hold the corresponding button on the remote control
(CBL) for approximately three seconds. The POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press the ON /OFF button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code located on the Code List.
If those are still a bust, try the GI SAT codes 018 & 019.
Have you tried the following steps with both CBL and then SAT to search it's database?
2. Press and hold the corresponding button on the remote control
(SAT or CBL) until the POWER INDICATOR on the remote control illuminates. The remote control is in programming mode.
3. Press and release ON /OFF. The POWER INDICATOR on the remote control flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns off.
5. When the device turns off, press any key to store the code.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
I hope that helps.
Oct 26, 2009 | Televison & Video
Advent Tv on direct tv with snow showing on screen
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Jul 22, 2009 | Recoton Advent Advent HT3251A TV
Model ht2751a no power,clicks and power light cuts on and off
I replaced caps in power supply.set work fine now.when off light stay blue,when on light is anber.
Jun 18, 2009 | Recoton Advent Advent HT3251A TV
Advent tv/dvd 27 inch flat screen. Weird Cable and power and volume problem
I have read that if you unplug the unit for more than about 4 hours, it will reset to the factory settings, and that wont be a problem.
this is at:
http://www.remotecentral.com/cgi-bin/mboard/rc-remote/thread.cgi?7770,1
I quote one guys fix below:
JazzyDaveNew Member Joined: November 2008 Posts: 1 View Profile
The factury remote that came with my 20" Advent lost many of it's functions. I recently purchased the Phillips Remote SRU4105WM/17 and it works perfectly with the Advent as well as my other equioment. Buy has it fo $8: http://www.buy.com/retail/product.asp?sku=208673201
Jul 02, 2008 | Recoton Advent Advent DV1418A 14 in....
Advent universal remote
You can also search for codes with out list.
switch on the power button manualy.
Press the program button on the remote press tv button and then channel up or down button. then the led on your remote will start blinkoing. when it reaches the correct code your tv will be switch off .then press program button once more or your remote.
Please try this option....
Feb 17, 2008 | Recoton Advent Advent ADR-560 Remote...
Looking for schematics for a Advent TV HT2751A HDTV?
try this
http://www.servicemanuals.net/
Jan 04, 2008 | Televison & Video
Advent HT2751A display no good until after 1-2 hour warmup - maybe
After 3 years, I finally decided to open up the TV and do some troubleshooting. Found out the problem, It was a blown capacitor Location C554 Capacitor value is 2200uF 16V - costs about a dollar to replace yourself and the TV works brand new.
Aug 16, 2007 | Recoton Advent Advent HT3251A TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
