Question about Refrigerators
Thermostat for proline ttr65p fridge needsed keeps freezing up
5 Suggested Answers
  • 202 Answers
SOURCE: fridge keeps freezing
If u change the thermostat and it keeps freezing the heater or timer are bad
Posted on Jul 24, 2009
sonicboomele
  • 1557 Answers
SOURCE: Fridge keeps freezing.
its not going into auto defrost the cause is either the freezer fan jammed or burned out the defrost timer but in 99% cases its a burnt out defrost element id start there replace it
Posted on Apr 21, 2010
Can't solve your problem, but just to report we have exactly the same issue, a huge block of ice forms on the upper rear panel. The compressor seems to be running 24h, not matter where the 'thermostat' is set.
I suspect that there was/are a faulty batch of thermostats. Or (since there is no metal cooling plate to bolt it to) that the T/Stat probe has somehow come adrift from its correct sensing area and is not correctly sensing the temperature inside the fridge.
If I get to the bottom of the problem, I will re-post here.
Posted on Sep 13, 2010
  • 5 Answers
SOURCE: Idesit BAAN134 PSUK fridge keeps freezing food
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Posted on Nov 02, 2010
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
My proline fridge freezer not cooling
I have the same problem with a proline plc 190w fridge freezer not cooling in the fridge compartment please help it's my mums and she can't afford a new one , thanks in advance
May 19, 2012 | Refrigerators
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
Jan 05, 2010 | Refrigerators
Jul 24, 2009 | Westinghouse Refrigerators
Hi my fridge freezes every thing even at it's
your thermostat is bad, what it does it sense the temperature set buy the control setting, once it goes bad it does not recognize the temperature hot or coold and the unit keep running and freezes everything. thermostat work like the therometer switch, when it reach certain temperature it cut off.
Jul 16, 2009 | Dometic Refrigerators
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Liebherr fridge 3150 keeps freezing
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Mar 03, 2009 | Liebherr KELB 2840 Premium biofresh...
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
