Question about Jenoptik JD C160 Digital Camera
Hello lost the disc for jd c160 to lode on my laptop help, brian thanks
Changed to windows 7 lost disc to down load pics
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Feb 26, 2013 | Jenoptik JD C160 Digital Camera
Where do i get the soft ware from to install my printer as ive lost the disc
Your printer manufacturer generally has websites with comstomer support pages with drivers to download by printer model.
I hope that you have found ths information helpful. If so, please leave positive feedback for me.
Thank You,
Brian
Jan 24, 2010 | Office Equipment & Supplies
How do i delete photos on jenoptik camera
if you can't delete the photos on the camera, maybe you can connect it to the computer and drag images to the trash/recycle bin and then empty it?
Aug 29, 2009 | Jenoptik JD C160 Digital Camera
Inserted disc reading "No Disc"
Hello Brian,
It looks like you have a bad lens assembly. That explains the "No Disc" error. Just get the lens assembly replaced and it will be back to normal.
Jan 31, 2009 | JVC DR-MV1S DVD Recorder/VCR
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Lost driver
did you get the drivers, post back
Dec 23, 2007 | Intel Shiva LanRover Plus Modem
Jenoptik JD C160 Digital Camera Logo
21 people viewed this question
Top Jenoptik Cameras Experts
Marvin
Marvin
Are you a Jenoptik Camera Expert? Answer questions, earn points and help others
