Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to install a ARMATURE-MAGNETO on a BRIGGS &STRATTON 18 H. ENGINE? Is there a certain gap between the fly wheel and the armature-magneto?
  • 51 Answers
Removw chop screen and blower housing unplug little wire under mag remove 2 screws and remove mag reverse prosess with new mag but pull mag away from fly wheel and snug screws center magnet on flywheel over legs of magneto place .010 feelre guage inbetween and loosen screws, hold mag against flywheel and tighten remove feeler guage reinstall kill wire on bottom of mag install blower housing and chop screen hope tis helps
Posted on Aug 08, 2010
Need gap specifications
The gap between the flywheel and magneto (pick-up coil) is not that critical, if your engine is not running right or won't start. 2 to 3 mm is fine. The key point is that the gap be uniform in the arc where the fly wheel passes it. Please post your symptoms and we can better assist you on the forum. If you are not getting any spark from the plug wire... check this at night by unplugging the plug boot and pulling the cord and watching; if you can't detect a spark... then you have a magneto issue or a bad spark plug wire. A little crokus cloth to rub the rust off the entire flywheel edge surface will help. Don't sand down or apply solvents to the magneto surface even if it's rusty!
Oct 12, 2014 | Garden
With a new armature magneto part # 591459 installed i don't get the new spark plug to fire . what am i missing ?
Check the spark plug wire and boot for continuity using a multimeter. If that isn't the issue, try reversing the polarity on the magneto wires.
Always check for a spark jump from the boot to the plug tip in near darkness, they are easier to see!
Oct 08, 2014 | Briggs & Stratton Garden
Is there a hot wire that goes to the armature on a 18.5 2 cly b&s engine
did you replace the armature or the magneto?the magneto has the plug wires on it the armature charges the battery if you put on a new magneto annd you have no spark check the safety switches
Apr 12, 2012 | Garden
I have a Sears 18 HP BS 31P777 Just got a long block moved every thing over and it will not turn over I get a spark on the plug and a backfire every once in a will but thats it Things I will check...
a simple way to set the gap is to use a couple of regular business cards (2) stacked on each other, loosen the magneto and let it fall onto the flywheel, with the cards in between, and then tighten the magneto hold down bolts, and spin the flywheel to remove the cards, with the gap you have the motor is fighting to fire and is doing so too slow, which is causing the backfire,
Jul 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Oegn.comThe 675 has become increasingly difficult to start, till today when it appears to be getting no spark (I don't see a spark, but it does shock me when i hold on to spark plug and pull cork). Is...
The magneto is self contained and the primary winding is grounded via the throttle stop, flywheel brake, or the low oil level sensor to ground the magneto enough to stop the spark from jumping the spark plug gap.
First check the oil level and make sure it is fully serviced.
Second check the Flywheel brake switch to see of the cable needs re-adjusted or replaced. There is a lever on the brake actuator that makes a ground on the primary of the magneto. ANY gound on the wire that goes from the flywheel brake, the throttle control (if so equipped) or the low oil level sensor will stop the engine from having spark. There is no condensor. The magneto is excited by the magnet in the armature each rotation of the fly wheel. Grounding of the magneto primary rreduces / stops the function of the magneto high voltage output.
You need to find out what is grounding the magneto primary when the engine should be in a running state.
Thanks for choosing FixYa,
Kelly
Jul 17, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
What is the gap between flywheel and magneto on a mower. I have a Craftman 6.75 hp mower and the magnets were rusty. I sandpapered them and was wondering what the gap should be
If you know the model number of it, this chart will surely tell you. I'm assuming it is probably a Briggs and Stratton engine. The air gaps vary say between .006" and .020" . Most of the time, on smaller engines like yours, .010" is suitable and works well. Here is the chart for All Briggs engine models. I use a business card to adjust because a feeler gauge sticks to the magnets.
Look in the third column from the left under armature air gap.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Jun 19, 2011 | Garden
Where is the generator on a yard machine lawn
no generator or alternator power generated by magnetic pulse[magneto]on the top of motor the fly wheel has magnetic inserts that pass thru a armature/coil causing a pulse sometimes the flywheel gets surface rust but that would also affect spark --check connections and test battery battery may not be holding charge or loose or corrosion in wiring can cause battery problem
Jun 10, 2010 | Yard Machines 155 Torque Briggs Stratton...
I have a Briggs & Stratton Sovereign 375 engine model no 1OD902 type 0129B1 code 03012751. No spark at all - any ideas please. Had the flywheel off - that's as far as I got. Bob
Bob, if you have the flywheel back on, first check the air gap between the magneto (ignition armature) at the magnets on the flywheel (a common business card works well for this) then unplug the small wire from the magneto and check for spark, if you have spark, repair the kill switch and/or wire, if NO spark, replace the magneto.
If you remove the spark plug, you can hand spin the flywheel fast enough to ascertain spark
Oct 11, 2009 | Garden
Installing Amature-Magneto
The air gap for the magneto is .010 - ,014. A microfiche card, an index card, a common business card or anything NON-magnetic of the above thickness makes a good shim to achieve this gap.
  1. Remove the old ignition armature mounting screws. Then, disconnect the stop switch wire from the flywheel brake and remove the armature.
  2. Attach a replacement armature from the original engine manufacturer, using mounting screws. Then, push the armature away from the flywheel and tighten one screw.
  3. Turn the flywheel so the magnets are on the opposite side from the ignition armature.
  4. Place the appropriate shim between the rim of the flywheel and the ignition armature. While holding the shim, turn the flywheel until the magnets are directly adjacent to the armature.
  5. Loosen the tight screw so the magnets pull the ignition armature against the flywheel and shim. Then, tighten both mounting screws and rotate the flywheel until the shim slips free.
Sep 21, 2009 | Craftsman Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
1,924 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
