Question about GE 29869GE2 Digital Answering Machine
How do I set the machine for longer than 5 rings?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GE Master
  • 102,366 Answers
Press and hold the SET button for two seconds to enter the change mode. Full details are in the "Changing the Settings" section beginning on page 9 of the manual available at
http://www.home-electronics.net/USER-GUIDES/29869_DOM_ES_AN_IB.pdf
Posted on Aug 13, 2011
Want to change the ring setting to 6 rings before i goes to fax mode how to do it
See the "Changing the ring setting of the telephone answering machine" section on page 60 of this manual.
Jan 31, 2013 | Panasonic KX-FG6550 Plain Paper Thermal...
I have the panasonic phone but when someone called me after 3 rings it goes on answering machine. i wanted to make it longer at least after 5 ring. please help me with any suggestion.
You can set your ring time to 5, 10, 15, 20, 25 or 30 seconds.
  • Tap **61*121*11* into your phone as if you're making a call.
  • Next enter a time between 5 and 30 (the number of seconds in multiples of 5)
  • Press # and then the call button. Don't put the phone to your ear - just look at the display until you see a message confirming your ring time has been set.
For example, **61*121*11*25# followed by the call button would set your ring time to 25 seconds.
Jun 11, 2011 | Computers & Internet
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
Have problem changing auto answer to longer than 3 rings
Press and hold the SET button to enter the change mode. The unit announces the current time and day. Press SET repeatedly until the unit announces the rings to answer. Press and release NEXT or PREVIOUS until the unit announces the correct number of rings for the answerer to pick up. Once the rings to answer is set, press SET to enter the incoming message length menu.
If you need a manual, you can download one here.
Oct 31, 2010 | GE 29868GE1 Digital Answering Machine
How to set the time, and longer than 5 rings to my digital
its network dependant any network will keep the line for 30 sec only for ringing
May 24, 2010 | GE 29875GE Digital Answering Machine
Will not pick up fax when sent to the correct number. Also we are unable to set or reset ring pattern for two longs, which it was always set for, but since the phone company made some changes to my line...
Set the FAX/MFC to MANUAL mode.
2 Press Menu/Set, 2, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scoll through the four patterns.)
Be sure to choose the pattern assigned by the telephone company.
5 Press Stop/Exit.
Sep 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Samsung j700 - Need longer ring time
Have you got in on automatic answer? if you have it will only ring up to five seconds, but then i guess it would answer the phone after those five seconds lol =/
Otherwise i cant help, i just looked all through the settings but im sure youv'e already done that..
Not much help am i, sorry!
Jan 30, 2009 | Samsung J700 Cellular Phone
Increase the number of rings
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Fax answer machine
FAX RECEPTION THROUGH AN ANSWERING MACHINE:
This mode is recommended for a shared fax and telephone line.
To receive a fax if your All-In-One is connected to an answering machine:
On the control panel, press Fax.
Set the answering machine to answer incoming calls before the All-In-One does. For example, if you have set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
To change this setting on the All-In-One:
Press Options until Number of rings appears.
Press the right arrow (+) until After 5 rings appears.
Press Select.
Make sure the Auto Answer light on the All-In-One is on. When a ring is detected, the answering machine picks up the call.
If a fax is detected, the All-In-One receives the fax, and disconnects the answering machine.
If a fax is not detected, the answering machine completes the call.
Feb 18, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cx9400fax
Epson Quick Guide is incorrect.
Not sure of your exact situation but .........
Your answering machine MUST be connected directly to the output of your CX9400 and you can't use an answering machine with multiple "mailboxes". Set your answering machine to 4 and your CX9400 to 5/6 rings. Epson "Technical Support" has no clue of this problem .... yet.
The machine routes the call to your answering machine, it it's an incoming FAX and the answering machine starts the CX9400 will recognize the incoming transmit signal, turn on the FAX function, and disconnect your answering machine.
You may need to adjust the CX9400 rings setting based upon the duration of your answering machines announce message (longer message = greater number)
Jan 28, 2008 | Epson Stylus CX9400 Photo Printer
GE 29869GE2 Digital Answering Machine Logo
35 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
