Question about Electrolux Refrigerators
My Electrolux 18cu top mount fridge is leaking blackish water from the front right side. Is something leaking? And how can I fix it? P/N 241857201
HVACRH20
  • 237 Answers
SOURCE: Fridge Leaking water from front right hand corner
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
Posted on Nov 10, 2006
SOURCE: internal water leak Amana AT5518SW
When water collects in bottom of frost -free fridge , first suspect is drain opening  behind plate covering evaporator in top freezer. Drain opening is into vertical tube running down to bottom of fridge and into collection pan under the fridge where the water is allowed to evaporate into room air. Reaching the drain opening directly is not always easy and blockage in my case was bits of matter. I was able to force water with a hose and fittings up this drain tube exposed with back cover off and had gunky-like material pour out of fridge. It was the solution.
Posted on Feb 02, 2008
TheMobilian
  • 8220 Answers
SOURCE: water leaking into fridge
When your frig defrosts the water should go outside to the pan on bottom but it ain't cause the drain is stopped up. So the water just floods the ice box. Solution: Clear dat popcycle paper clogged drain up . Use some hot water to flush out dat drain.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 10, 2009
  • 415 Answers
SOURCE: stuff in bottom of fridge freezes
I would try to ajust the control for the freezer to a higher setting and turn down the frig thermostat setting if no frzr ajustment just turn down the thermostat for the frig
Posted on Aug 19, 2009
  • 61 Answers
SOURCE: Kenmore top mount refrigerator freezer, ices up,
sounds like could be defrost timer or heater issue...when in doubt contact a pro
if you need a part try www.appliancepartssolutions.com
Posted on Jan 16, 2010
Electrolux PLHV42P8CC/two lights working two out and replacing bulbs does not fix the issue
Good Afternoon Rick,
I see that you are having trouble with the front right and back right halogen lights not working on your Electrolux range hood, model# PLHV42P8CC. I also see that you have heard of testing and replacing the transformer inside your appliance. I suggest contacting an authorized technician. It could possibly be something other than the transformer or it is possible that it is the transformer and something else that is causing the right side lights to not come on. Hope this is helpful.
-Best Regards-
WP
Apr 16, 2014 | Electrolux EFC90244X Kitchen Hood
Sears Kenmore refrigerator 18cu frost free. Water constantly flows down the back of the fridge and collects under the vegetable bins. How do I fix it?
sounds like the drain pipe is blocked. turn it round and at the bottom there is a pipe check its not blocked. to clean out use an old curtain wire or something that can get up the pipe and flex.
Nov 03, 2013 | Kenmore Refrigerators
Electrolux ide by side ESE6077SC fridge side leakes water near door corner. Dood does not seem to have much vaccum suction.
You either have a stopped up drain which can be confirmed if you have ice on the freezer floor, or the tube connector beneath the door is leaking.
Mar 28, 2013 | Electrolux Refrigerators
Puddle of water on floor in front of side-by-side fridge. Fridge and freezer are cold. Drain pan is dry.
Lets make sure it is not something simple like a leaking water line behind the front kick plate. With that answered click here=> Leaking Refrigerators Just What may Be Happening Much more on this page=> Leaking Refrigerators! If you have questions please ask, Thanks Sea Breeze
Sep 23, 2011 | Whirlpool Refrigerators
Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Jan 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Haier fridge running but nothing cold
This is rare when you look at the total average of refrigerators being sold. Even the best refrigerators have defects every now and then.
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Change Kenmore fridge water filter due to slow water dispenser
what you want to look for on the filter is an arrow turn the arrow left and then pull down
Dec 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Refrigerators Logo
49 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
