Question about Craftsman 25cc Gas Line Trimmer
I have a 32cc Craftman Brush wacker trimmer and the fuel line fell apart I need to know how to install the new ones.
    President:
  • Craftsman Master
  • 1,545 Answers
This problem seems to be the biggest and most popular one by far in these forums and has been answered several times. Try and post your problem using the search feature on this site. Don't use too many words. Craftsman Weedeater Fuel Lines should be sufficient. If you can't get it, then post back here again please.
Posted on Aug 07, 2010
Where do all the gas lines hook up on craftman model 358.791170 on primer it has a long nippel and a short nippel to hook to it is a 2009 32cc model
Take the primer bulb off and use two new fuel lines and dip them both in fuel. Push the primer bulb to see which side returns the fuel, this is the line that will go from the bulb to the tank, the other line goes to the carb.
Sep 11, 2014 | Garden
Fuel line diagram for craftsman 32cc weedwacker weed eater
digrama for weed wacker 32cc modelo 368791156
Aug 23, 2012 | Garden
17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Sep 19, 2011 | Craftsman Garden
Craftman 32cc model 358795560.From the fuel tank to the primer to the carb.Which line go where.
Hi glen11234...
Normally the big line will be the line the fuel filter is connected to inside of the tank.
The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Jun 27, 2011 | Craftsman 25cc Gas Line Trimmer
My craftsman 32cc weed wacker (model#358.791071) dose not start.
Many things to check. Spark, fuel and compression. Check these to narrow it down.
Nov 27, 2010 | Craftsman 25cc Gas Line Trimmer
Try to replace fuel line craftman weedwacker 32cc/1.9c.u -trimmer-hose all rotten cant figure how to replace
You will need to get some TYGON fuel line. Match it up to the size of each fuel line, some of these trimmer use two different size lines, and remember which size went on which connection. You will want about a foot of each. Cut one end of each line at a 60 degree angle. With a pair of needle nose pliers, feed the angled end of the fuel line into the hole going into the tank and feed it into the tank untill you can see at the tank fill. You cut the angled end off and put your filter on the line. Pull it back until the filter lays at the bottom of the tank. Hook this line up to the supply side of carburetor. Take the other line and put it in the tank about 1" or 2"
then cut it off to fit on the carburetor. HTH
Good Day.
Nov 10, 2009 | Craftsman 25cc Gas Line Trimmer
I need to replace to fuel lines on a Craftman 32cc trimmer. The old ones cracked apart. 2 of the lines look like 1/8" OD one line looks like 3/32" OD. Larger line looks like it hooks to filter, Smaller...
Depending on the brand of line you use, Tygon line is self sealing but seems to shrink faster then factory supplied because of the ethanol in the gas. The stone gas filter is designed to fall to the lowest part of the tank, not stop the line from falling out.
Nov 01, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc weed eater wont start. Push in the primer bulb and it does not refill, stays stuck in!
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Craftsman 25cc Gas Line Trimmer
I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Istuctions for fuel line installation on weed wacker
The esiest way to figure it out is to take the line with the filter and put it on one nipple then push on the primer a few times and see if fuel comes out of the other, if no fuel then switch the line over to the other. But if im not mistaken the filter will go to the bottom.
Oct 20, 2008 | Homelite Consumer Products 4.0 Amp, 13 In....
Craftsman 25cc Gas Line Trimmer Logo
428 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
