Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
My Bissell steam cleaner works well on plush carpet, but on berber, there is very little suction. Most of the water is staying in the carpet, which worries me as it's in a cool basement and could lead to mould. Any suggestions?
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101 ..
Posted on Oct 28, 2010
When bissel turbo steam cleaner wont suck
google it:
My ProHeat 2X® is not suctioning properly. What ... - Bissell
www.bissell.com/faqdetail.aspx?id=1124 BissellAnswer: Let's start by figuring out where your carpet cleaner has suction. Check for ...If the Lint Screen is dirty, the suction won't be very strong. Cleaning the
Jul 20, 2015 | Vacuums
Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
Jan 30, 2014 | Bissell 1699 ProHeat Clear View Upright...
Will not **** the water off the carpet.
If the carpet cleaner won't "Extract" water from the carpet, try using the upholstery / hand tool. If you have suction there, your selector switch / knob is either in wrong position, or broken. There may also be a tear in the hose on the inside of the cleaner, or the waste tank is not sealing well.
Jun 13, 2010 | Bissell 1699 ProHeat Clear View Upright...
Bissell carpet cleaner doesn't **** up water
Turn the selector on the side from tools to floor.
Oh yea, could also be the seal is missing from between the tank and the suction nozzle. Could also be the tank is not seated correctly.
May 23, 2010 | Bissell 1699 ProHeat Clear View Upright...
It won't move forward. it turns on but drags when going forward will go backward smoothly.
On the front of Carpet claner is the clear part that pulls the water back up. It may have come apart. this will cause it to catch, unplug the cleaner, remove all the cleaners and water container, then , lift up and look at this part, If it has a large gap it has come apart.
Mar 24, 2010 | Bissell 1699 ProHeat Clear View Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
My carpet cleaner
There is a black ovule shaped gasket that sits between the top of the window nooze and the edge of the tank. If it is missing, then you lose suction at that point. Also is the filter on the end of the tank that sits over the square outlet clean?
Mar 22, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
116 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
