Hi there I have an old stereo receiver its a Technics model # SA-GX470....I need a manual ....I'm trying to hook up surround sound that used to hooked up to it,, but I can't figure out the ports exactly right....need to see a manual
cancerags
  • 36 Answers
SOURCE: Surround speakers don't work
Hello barstep,
Let's go through some steps that will help alleviate your problem. We'll start from the simple to the not so obvious:
1.- Perform a visual inspection on the back of the receiver and verify that all speaker connections (specially the surrounds) are not loose, shorting out another connection or are pushed too deep into the speaker connector so the wire insulation prevents proper contact. If this is not the problem then...
2.- Get into your receiver's "Manual Setup" and verify that your surround speakers are set either to "SML" or "LRG" but not "NONE".
3.- Verify the receiver is not in "Straight" mode, shown on the receiver's display. I f so, press the "Straight" front panel button until indication disappears.
Your owner's manual can give you detailed information to access the setup menus.
Hope this information helps. Let me know if we can further assist you.
cancerags
Posted on Dec 30, 2007
marsrover
  • 682 Answers
SOURCE: hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Posted on Mar 11, 2008
SOURCE: Device code for Technics SA GX530
I would TellYa but it would require that you first sign up for the TellYa Premium Plan. Best of luck with this little scam.
Posted on Oct 02, 2009
  • 4234 Answers
SOURCE: Manuals For Technics
The manuals for these are on paper not electronic files. Is there are particular problem you are trying to solve?
Dan
Posted on Jan 06, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a Technics Stereo Receiver SA-GX 500.
All sources or just one? Make sure the Tape Monitor isn't engaged unless you're using an external tape deck or processor. A turntable will only work on the PHONO input.
Posted on Aug 09, 2010
Would I be able to connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
Yes, it is hooked up using the (cassette) tape inputs and outputs. Use the tape monitor switch on the receiver to switch the EQ in or out.
Feb 11, 2016 | Panasonic Technics Sa-dx930 A/v Stereo...
Can i hookup a television to my receiver for sound
Yes. You can hook it up using a digital coax or optical cable. Use can also use old stereo, analog, left and right channel audio. Use any audio input on your Technics, that will accept any of the inputs above.
Feb 09, 2015 | Technics SA-DX940
Can you have just 2 channel by hooking up to right & left front speaker posts on 5.1 surround
short answer.....no. If you hook more than one speaker up to a single channel, it will lower the impedence and will damage the amp. You can hook up multiple speakers by using a speaker switch box between the speakers and the amp. This will match the impedence and should keep the amp from blowing.
Dec 21, 2014 | Panasonic Technics SA-G76 AV Control...
I have a Technics audio receiver, model SA-GX650. The front speakers work correctly, but the back and center speakers do not work correctly, i.e. no volume comes out of them. Would you please let me know...
Some receivers have adjustments you can make during set up to direct sound in various ways. There also may be configuration selections you can make using the remote. For example, enabling surround sound or selecting simulated stereo. The instruction manual should explain the various options.
Nov 23, 2014 | Technics Audio Players & Recorders
Can i hook up my technics sa-g76 to my tv
yes, using the the rca outs of your tv, and they will connect to an input on your reciever that may already be marked for a tv, or cable box
Jul 28, 2013 | Panasonic Technics SA-G76 AV Control...
Panasonic Original Technics Sa-370 Stereo Receiver Service Manual
Hi Dan,
I also have the Technics SA-730S an now its not functional. Could you please assist me.
Rozario
Dec 19, 2012 | Panasonic Original Technics Sa-370 Stereo...
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
Dec 29, 2007 | Technics SA-DX1050 Receiver
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
53 people viewed this question
 Grubhead
Grubhead
