Question about EuroTech EDC158 Electric Dryer
My dryer take forever to dry. The "delicate" light turns on even when I have not pressed the delicate button. It is due to this fact that I believe the dryer is taking so long to dry. What can I do?
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
I own a FP dryer model number DE08-US1, serial number VF740275A. Recently the dryer has been automatically starting when I turn the drying dial to any of the drying options (Automatic cottons, automatic...
I really hope the problem is the start button is defective, it is stuck on. You would need to get a new one. Bad news is, that is a little bit more rare than the timer itself being messed up . Those are quite expensive.
Be blessed.
Sep 01, 2013 | Fisher and Paykel DEGX1 Electric Dryer
Turned on Dryer today; problem; Estimated time remaining window shows CL (no time) Non of the time buttons selected show time in window. Dryer runs forever; gets hot and drys clothes. Pause button does...
The Child Lock feature is activated and it can be deactivated by pressing and holding the DRY LEVEL button for 3 seconds or until the CL display is cleared.
Indicate the exact model number of the dryer if the control panel doesn't look like the one shown above or if no button with the small "PRESS & HOLD 3 SEC TO SET CHILD LOCK" (DRY LEVEL) marking is found.
Mar 06, 2011 | LG DLE2514 Electric Dryer
How do i get the control lock button to turn off?
There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
Sometimes the problem is due to electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
Beeping Sound on Dryer
okay, this same problem happen to kenmore elites, the touch panel will automatically come on and beep even when it suppose to be off, replaced not the board but the touch panel and you will be okay.
Aug 17, 2009 | Frigidaire FEQ1442ES Electric Dryer
I press the start button, the light goes on but nothing happens
I had the same problem. It is the door latch. It cost about $150 to fix. I can't believe the tech didn't know it. It is very common for Bosch Dryers after about 3-4 years old.
Jul 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Amana gas dryer fine on regular settiing, poor on delicate
It would be unusual but this could be a bad timer in the control panel. The only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru --- www.RepairClinic.com
http://www.repairclinic.com/Amana-Dryer-Parts?z=100
Jan 26, 2009 | Amana ALG331RAW Gas Dryer
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
EuroTech EDC158 Electric Dryer Logo
71 people viewed this question
Top EuroTech Dryers Experts
Tim Whalen
Colin Stickland
Colin Stickland
Are you an EuroTech Dryer Expert? Answer questions, earn points and help others
