Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
My flash is too bright...
I've had my Nikon D40 for less than a year and I just started usuing it really frequently. I just moved so I have no clue where my manual is right now, and I have a problem. I was using my camera the other day and it was working beautifully and then all of a sudden my pictures were coming out almost compltely white. The flash is almost blinding and I can tell something isn't right, but like I said I've been using my camera for a short while and am still learning all the controlls. I tried playing with the exposure compensation, but maybe I'm not doing it right because it doesn't seem to be working. Any help would be greatly appreciated. :)
  • nshaw May 11, 2010
    Might be worth seeing what flash mode you're in - manual or TTL.
    If you go to the Custom Settings menu, the Flash Mode should be item 14, assuming you're in the "Full" version of the menu (CSM/Setup Menu option in the Setup menu)
  • 111 Answers
Flash also has several modes you can toggle through by pressing and holding the button that pops up the flash while using the command dial to change modes... rear curtain, slow sync, red eye reduction, etc. These show up on the top LCD under the lightning bolt icon.
Posted on May 17, 2008
Hi, i am using nikon d40 my problem is that i was using 18-55 lens after some years there was green spots on my pics when clicked,i started using 18-105 mm nikkor lens my problem was solved but now af
The D40 is a low end camera, but before you discard it, I would contact the closest Nikon repair depot (see the Nikon website for the location) and ask them for a repair estimate. You will then be able to decide if it is better to have it repaired or replace it with a newer model.
Jan 08, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
How slove the problem
Introduction
Specifications Recommendations
The Nikon D60 is an inexpensive 10 MP DSLR that comes with an excellent 18-55mm VR lens for about $650 as of June 2008. It was a announced in January, 2008, and sold for about $750 with lens in February 2008.
The Nikon D60 is a replacement for the almost identical D40x.
Personally I prefer Nikon's least expensive D40 over the D60 or D40x. The D60, D40x and D40 are actually exactly the same cameras, differering only slightly in their internal electronics, but differing greatly in their prices.
The D60 is actually a D40 body with a few more card-clogging pixels, a VR lens and adaptive dynamic range, but a slower maximum shutter speed with flash.
The D60 is less sensitive to light then the D40 (its default ISO is only ISO 100 compared to the D40's default ISO of 200). Its less sensitive to light because the pixels have to be made smaller to cram more of them into the same-sized sensor. Smaller pixels collect fewer photons than larger pixels. Since the D60 is half as light sensitive, the D60 has to use twice as long a shutter speed or a larger aperture, which makes it more likely to make a blurry picture than the D40. OOPS!
Save your money and get the D40 instead. The D40's faster sync speed is invaluable for use with flash outdoors, and the extra light sensitivity in normal use will help make sharper pictures. These three cameras (D40, D40x, D60) otherwise, for most users, are identical. Compare them in person and you'll see. Megapixels don't matter.
(I detail the few fine points which are new in the D60 further below.)
I had my hands on a D60 back in January 2008. The D60 is an excellent camera, but for most of the people who will buy it, it's the same thing as the $300 less expensive D40. I'd suggest getting a D40 and putting the $300 towards more lenses and/or a bouncable flash.
In fact, the faster flash sync speed (the fastest shutter speed with flash) is more than twice as fast in the D40 (1/500 vs. 1/200), and along with the faster base ISO, the D40 is more likely to make sharper photos for most people, for hundreds of dollars less!
The only significant feature in the D60 over the D40x and D40 is adaptive dynamic range. The D60 does not have any of the other next-generation functionality of the D3 and D300.
The D60 is just a D40 with more pixels, but slower shutter speeds with flash outdoors and less basic light sensitivity due to the smaller pixels needed to jam more of them onto the same-sized sensor.
I make excellent 12 x 18" (30 x 50 cm) prints from my 6 MP D40; do you plan to print bigger? Really? The resolution makes no difference unless I'm printing at 20 x 30" (60 x 80 cm) or more.
Since the D60 costs $300 more than the D40, I'd much rather have a D40, 1/500 flash sync for better daylight fill-flash range, a minimum ISO of 200 and $300 left over to buy lenses and an external flash that I can bounce for better lighting. For instance, the D40, 55-200mm VR and SB-400 is a far better way to spend the same $750.
Sep 19, 2011 | Nikon D60 Digital Camera
Blurry pictures
THE IMAGE SENSOR OF YOUR CAM ARE HAVE A BURN SPOT
Aug 18, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
The flash is to bright i have a really bad picture at night... peoples skin is really white and so is almost everything else
Most cameras have a function where you can decrease or increase the brightness of the flash. I, too, had that problem on the built-in flash on the Nikon D40, so I toned it down to -1 power, which illuminated the subject but didn't wash out. Also, if you're shooting an external flash, try toning the ISO settings on the flash to a lower number or decreasing the power. Also, angling the flash away from the subject slightly helps a great deal.
Jul 07, 2009 | Sakar Digital Concepts Digital Camera and...
Can you use nikon sb25 flash with d40 dslr?
You can but with limitations;
Save me explaining,please read this http://forums.steves-digicams.com/nikon-dslr/137618-sb-25-d40-non-ttl-auto-mode.html
Apr 14, 2009 | Nikon D40 Digital Camera with 18-135mm...
The flash on my camera
There is no top LCD on the D40. Put the camera in AUTO mode (green icon on the dial) and take a picture in the shade. if the flash does not go o, then you have a fault. Send back to authorized repair centre.
Dec 09, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40
Hey timrowan,
What you’re seeing is your playback mode is set to highlight, which flashes all the highlights (bright areas) of your images that are overexposed. If you don't like this viewing option you should be able to change your viewing mode by pressing mutiselector button to the right or left until you get to normal viewing. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
My Nikon d40 build in flash not working after fall
I have also had the problem of flash not working on my Nikon D40. I found out the problem and I made a quick video to help those who are having this problem. Here's the link to the video: Hope this helps !
Nikon Flash Fix
Oct 04, 2007 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
222 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
