Question about Dell Latitude C600 Lcd LCD Display
I had turned my computer off to clean screen and key board and had accidently pushed the on button a couple of times while trying to clean key board and had turned it off by the power button.now that i got it cleaned cant get the screen to come back on even though the computer is powering up.
  • 27 Answers
Press the fuction key and at the sametime press the alternate screen,f7 or f4
Posted on Aug 10, 2010
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
Accidently pushed Zz button at top of key board Screen went black what now??
Sounds like you've put your computer into sleep mode. Hitting Escape or clicking the mouse will usually bring it out. Otherwise just tap the power button one (on the tower, not the monitor) and that should bring it out!
Mar 10, 2011 | Computers & Internet
My lenovo think pad x60's screen has turned sideways. I think I pushed several buttons at the same time by accident. Help!
Typically the hotkeys to rotate the screen are Ctrl+Alt+Direction Key. Ctrl+Alt+Up Arrow should restore your screen to the correct orientation.
Dec 10, 2010 | Computers & Internet
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error0xc19a0024 on a hp 6180 will not print
Follow the below 2 solutions :-
I
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the connectors on the main circuit board.
II
  9. Scan again and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan again and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  13. Reconnect the flat ribbon cable by aligning and carefully pushing into the connector on the main circuit board.
If problem persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 07, 2009 | HP Office Equipment & Supplies
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Yaesu Ft-50 hard to turn on
The rubber power button is impregnated with carbon and when pressed, it makes contact with two points on the printed circuit board, turning on the radio. This button eventually wears out and needs to be replaced, which is a rather easy process.
I've performed the operation four times - takes about 15 minutes. The button is available from Yaesu.
I also tried "repair kits" for these buttons which are supposed to replace the conductive surface. Both times, they failed again within a couple of weeks.
The upside is the new button is not as quite as tall as the original and requires depressing it below the surface of the case to switch, which prevents accidently turning off the radio.
Good luck, and 73
DE NøAWN
Mar 17, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-V47...
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
The 4 wheel drive doesn't work in my 89 Ford Bronco
The sound is not coming from the glove compartment, it is coming from the panel behind the drivers seat, that's where the relays and computer are located.
The relays click and apply power to a transfer case motor.
The motor attempts to turn a shaft that engages the front drive shaft.
When the computer thinks the shaft has NOT turned it tries again.
It will try three times then quit, figuring the shaft has not turned.
Get someone to crawl under the vehicle and engage the 4WD (just turn on the ignition- do not start the engine) See if they can hear the motor attempt to turn the shaft, it will make a clicking sound.
If not the connections or the motor may be bad.
I have found the most probable cause is the relays on the control board.
If you are technically adept --
you can remove the small side panel from behind the drivers seat and remove the control board. (remove the power plugs first)
Clean the relay contacts and bend them a little to give them more 'wipe' to keep them clean longer.
Put it back in and turn on the ignition.
Then push the RESET button on the side of the board.
Try the in / out 4WD a couple of times. If it doesn't work turn off the ignition, turn it back on and push the reset button again.
Oct 16, 2008 | 1989 Ford Bronco II
Lights on, nobody home
By accident, I did a hard restart while plugged into my computer. That fixed it. Don't know why.
Mar 29, 2008 | Palm Z22 Handheld
Dell Latitude C600 Lcd  LCD Display Logo
149 people viewed this question
Alun Cox
