Question about RTO Boating
Hi got a 4ohp mercury cant get the gearbox off drops down about 5mm and thats it have i missed something
How to remove lower unit from leg of 7hp. eska sears outboar
Don't know if this will help, but there are some educational videos on YouTube:
https://www.youtube.com/watch?v=HRpfaOiXxWo
I hope this helps you out!
Feb 12, 2017 | Sears Garden
02 mercury sables starts but within 6 minutes shuts completely down. Won't start for bout 15 minutes later then shuts down again.
Something electronic is overheating , transistor , . the engine computer , ignition module . crankshaft position sensor. Also check PCM power relay . losing power . Check for spark , fuel pressure when it stops running , see what is missing .
Jun 21, 2016 | Mercury Cars & Trucks
How do i undo the gear linkage on a mercury 40 hp 2007 lightning Xr to drop the gearbox to replace the impeller
put engine in forward gear then drop the gear box and the gearlinkage seperates as its on a spline male and female connection !
Sep 26, 2013 | Mercury Impeller - 3 Cycle, 40hp
Ive been using this phone and its been fine. All of a sudden today i get a call from my wife and i can hear her but she cant hear me. I thought it must be on mute or something but its not. I went thru the...
hi!
no problem it all friend..!
there is a chance of problem in ur phone mic..!
simple solution is to take off the phone panel
try to give gentle press of ur mic..!
do not press with any harder materials which may affect ur phone try to use ur fingers..!
there is a several possibilities may cause this mal functioning lyk dropping down several times..!
try it down there is a chance for working fine..!
Feb 14, 2011 | Cell Phones
Utencils touch the bottem of bowl
it sounds like the planetary has gotten loose and dropped down. Check out this parts list so you can see how it is put together.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
Try pushing up on the shaft which holds the mixing attachments. It should not move more than 1/32 inch - if it does then something inside the gearhead is worn and you will have to take it apart. If the whole planetary moves up and down then something deeper in the gearbox is worn.
To take it apart lay it on its side and carefully pry the chrome ring off. Now drive out the pin that goes thru the planetary and the shaft. Now pull the whole planetary off its shaft. Remove the six screws underneath plus the other screws you can see from the bottom of the gearbox - there are 4 more. Now carefully pull the top half of the gearbox from the bottom half, which will expose the gears. Examine for worn parts and replace the necessary ones.
Apr 12, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Torque converter locks up when cold. Chatters and vibrates when hot?
hi, unfortunately a torque converter is non servicable as it is a sealed unit... you will have to replace it but that does involve removing the gearbox so i would first change the oil in the gearbox just incase it has something to do with that..
Feb 10, 2010 | 1995 Mercury Cougar
Im looking for all drivers for mercury kobian 740 ecs?
here it is...
http://www.ecs.com.tw/ECSWebSite/Downloads/Category_Download.aspx?MenuID=6&LanID=0
select motherboard in the 1st drop down
select lga 775 in the next drop down
select 661fx-m7
select ver number in the next drop down
click submit
and there we go
please rate the service you have recieved
Apr 24, 2009 | EliteGroup ECS 661FX-M7 SiS 661FX Chipset...
Eiki EIP-25 shuts down after 30 sec (ceiling mounted)
there must be something loose inside. maybe the button panel.
Mar 07, 2009 | Eiki LC-X50M Projector
Taking a gear box out of a evo 7
when you pull trans all of the trans comes out even the transfer case
the drive shaft just needs to disconnected
make sure you have help droping the whole tranny cause its going to be heavy
Jun 07, 2008 | Mitsubishi Lancer Evolution Cars & Trucks
Boating Logo
Top RTO Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
