Question about Linksys WRT120N Router
Hello - I have router wrt120 and it always disconnect from the internet, To reconnect I need to get into the router and press the connect button on the status sheet. Do you know what is the problem? thanks
Do you have keep alive active on it? If not set it to the default.
Posted on Aug 07, 2010
Why does my acer aspire 5315 wifi keep disconnecting and reconnecting?
hello sir.
Reason :-
1.Make sure your acer aspire is in range.
2.cheack is it your wireless disconnecting and reconnecting or is it your internet disconnecting and reconnecting.
3.Are you facing this issue with any other machine or is this the only one.
If this is the only computer in which your wifi connection is dropping then there is issue with wireless connectivity.
solution:-
1.Turn of your router and modem and then check the wireless connectivity.
If issue still persist then:-
2.Create a new network name and wireless security key and then connect to it:- Now check the wireless stability whether is it still disconnecting an reconnecting or is it stable now.
If issue still persist then bright your laptop close to router and then check wifi disconnecting any more or not if not then change the channel to 1 or 11 from your wireless router page.
Let me know if this worked for you or not.
If worked then please rate my solution.
May 25, 2012 | Acer Aspire 5315 Notebook
I am using Linksys Wireless- N (wrt120) and my download speed seems to work great but when I browse the internet my pages won't load. Sometimes they will load very slowly. It seems like the connection
There may be competing wireless routers or networks nearby on the same band. Within the router's interface, try switching to a different band (2.4 Ghz vs. 5.0 Ghz) or use different radio channels. By default the router will attempt to do this automatically, but you may want to try adjusting them yourself and see what you get.
Oct 24, 2017 | Cisco - Linksys Wireless-n Home Router -...
Wont reset and has erratic blinking lights. Tried power reset, reset button, etc.
Does the power light blinks when you press the reset button?
If power light is blinking continuously then I think your router is not working and you need a new one.
Read how to reset Linksys router
Oct 09, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Last january my d-link WBR-2310 still working fine but now i wanna use it, it wont connect in the net?
Try power cycling the router.
Disconnect the router from all computers. Power off the router. Power on the router. Reconnect the router to all computers. Check the Internet connectivity.
Mar 01, 2011 | Computers & Internet
WRT120N---I keep having to disconnect my linksys, unplug all 3 wires on the back of the router, wait 30 sec...reconnect the router...try to get online...when it works then reconnect the linksys....what am...
Please disconnect and internet link and try to access the the Linsys WRT100 management page and see the logs why the router is loosing the connection. If you dont get anything then it might be some issue on the device. A reset may solve your issue.
Please be aware the if u reset the wireless Router you will loose all your configuration and you have to reconfigure the wireless Router.
Please press the tiny black button at the back/beneath of the wireless Router and keep pressing for 2 minutes. The sys light will start blinking slowly and then rapidly. then release the button and wait for 2 minutes for the device to boot up with factory default settings.
Once you are done you can connect to 192.168.1.1 ip address and it will open the your Linksys Router management web page where you can reconfigure your wireless router again.
Hope this will fix the issue.
Best Regards
Jan 01, 2011 | Linksys RangePlus WRT100 Wireless Router
I have a linksys WRT120 connected to my home network. I have one computer "wired" directly to the router and one wirelessly connected with WPA2 security. Last week i was having connection issues with the...
I'd suggest that you reset the Router to its default factory settings. After doing so, when opening a browser, you should be prompted to initiate the setup wizard. Once set up I recommend checking for any recent firmware updates.
On the WRT120 the Reset button is located on the
right side of the product label. There are two
ways to reset the Router to its factory defaults.
a) Either press and hold the Reset button for
approximately five seconds.
b) Log into your router and restore the
defaults from the (Administration > Factory
Defaults) screen of the Router’s browser‑based
utility.
Check out the Linksys Support Page for your router.
I hope this helps!
Good luck and Please rate :)
Jul 30, 2010 | Linksys WRT120N Router
F5D7234-4 unable to connect to internet with router and forgot passwords
Hello, If you are locked out of the router you will need to reset it. There will be a small button (usually at the back) with reset wrote beside it. You will probably need a paper clip or something to push it.
Next to the power supply connection is a pinhole Reset button. Disconnect all cords from your router except the power cord. Press Reset button with a pin for 10 seconds. Wait 10 more seconds then unplug router. If it is then reset to the original factory settings you will have to reinstall it using software that came with router. You may have to reinstall your network card software as well.
Some, but not all, routers have a reset button. Different routers require different steps to perform resetting. On many of them, to restore your own "personal setup" that was created when you first installed the router - not the original factory settings - you just have to disconnect the power supply and reconnect it after a minute or two. You will need to locate and read the manual if you cannot get to Belkin's support site online.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 26, 2010 | Belkin F5D7234-4 Router
My test light comes on every 5 minutes or so and disconnects me from the internet. it just started doing this yesterday. it is hooked up correctly but i will be on the internet then a no connectivity box...
Hi ,
This is Neo . Thanks for contacting us .
Reset your Netgear and Try it again .
The steps to be followed are ,
STEP 1
Reset the Router by pressing the RESET button on the rear till the Test Light blinks.This takes about 10 seconds . Use a pen or paper clip to access it .
Release the button and wait for the Router to Reboot.
STEP 2
Login to the Router with the default Password. The Router has the default User Name as 'admin' and the default Password is 'password' .
STEP 3
If the Router was not cleared after rebooting, unplug the Router's power . Then Press and hold the Reset button.
STEP 4
While the button is held down, reconnect the Router's power . Continue to hold the Reset button for 20 seconds after reconnecting the power . Wait for the router to reboot .
Then Login to the Router with the default Password. The Router has the default User Name as 'admin' and the default Password is 'password' .
Do the setup and try to connect to internet .
The Router will work .
Thanks & Regards
Neo
Thanks for using FixYa.com.
Dec 21, 2009 | NetGear WGT624 Wireless Router
Cannot connect to internet through the router. Working fine last week, not working now. What's up? Can you help?
Power off ur Router > disconnect all the cables>
find a button that says RESET or it can be a pinhole> press and hold on it for 30 seconds > reconnect the power and wait till all the lights come on> reconnect all the cables try connection> if still no connection>
do the same for the modem( and do check if a Wired connection is working with both the devices)
Oct 20, 2009 | NetGear WGR614 Wireless Router
Linksys WRT120N Router Logo
471 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
