Question about Goldstar Heating & Cooling
Model GWHD5000, -5.000 BTU. Room air-conditioner. Suddenly stopped working. See no reset button or reason for problem anywhere. Outlet live and OK. Thoughts? Thanks! Dan
    Genius:
  • 1,417 Answers
the problem of your air condition can be view from two point
1).power problem and(wire)
2).overload from the capacitor(thermostat power distributor)
what you are to do to solve either of the two problem of your air condition put of the system for some time that is disconnect the wire connected to the main power supply, after some time put on to see it respond solve but if this fail then it then mean that the thermostat will need to look in to
The way out to replace the thermostat unscrew the screws trace the wire down to the compressor it is black in color it look like a put the thermostat is connected to it but note this as you are tracing the wire down to the compressor then note if there is any form of wire or born wire if there is replace the loose or born wire but if non then you will need to replace the thermostat.
thank you and thanks for using fixya.
Posted on Aug 07, 2010
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
I don't know why it is not cooling my room?
Refrigerant leaked out? When did it last work properly? Did it suddenly stop cooling, or gradually over time?
Jun 01, 2015 | Kenmore Portable Air Conditioner 10000 BTU...
Unit has been working but suddenly stopped and won't turn on. what is the problem?
Look for a little compartment of slot for a fuse or a reset button. Do you have the owners manual? That might give you some solutions as well.
Jun 17, 2014 | Haier Commercial Cool 8,000 BTU Portable...
Why did my 5,000 btu artic king air conditioner stop working after having it less than one day?
Can't answer why as no details as to how it's failed, but if you've only had it a day return it to the vendor.
you have installed it as per instructions? Is it draining ok? No error codes? Checked the power outlet? Fuses or breakers?
Jun 17, 2014 | Arctic King MWK-05CMN1-BI7 5,000 BTU...
AC stopped working - only flashes "PF" now.
I found the instructions call 1800 322 3848... My just said the same thing
Sep 10, 2012 | Kenwood PAC C130EK 13000 BTU Portable Room...
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
Air conditioner was working great suddenly STOPPED working...cant turn it back on.
Hello
Is there a reset button located near the plug? If so reset it.
Check your circut breaker for the outlet its plugged into also.
If your using a remote to start this unit check that the battery is good in the remote,it may only work with a remote.
Jul 21, 2011 | Kenmore 76129 Air Conditioner
When I plug in the unit it trips the reset button every time. Its
This is only a 5,200 BTU unit - for single room use.
If you're sure the voltage ok, it sounds like the unit is new and should be under warranty.
Jul 25, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
