Question about Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi
Lost compression - Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi
  • 34 Answers
Probably a bad o-ring seal. Take it to a local repair chop.
Posted on Aug 10, 2010
I've lost compression in 4 cylinders on my 2001 dodge darango, what could it be?
There is a lot more to this than just lost compression. You need to know what the difference between all the readings is. Some variance is not a big issue. A compression test is not that good of a diagnostic tool. The use of a leak down test would be better because you can tell if it is rings, valves, or gaskets.
Feb 05, 2016 | Dodge Cars & Trucks
Whats wrong when my car looses compression and stalls?
Possibly not lost compression. May not be proper mix of fuel and air. Check the exhaust for blockage.
May 07, 2015 | 2007 Toyota Camry
My daughter was driving my 1997 sunfire and said at 65 or 70 lost compression and it over heated what does that mean
This is what happened to me. I had lost coolant (because of a crack in the radiator, the engine overheated, and cracked the head. I was going 75 down the highway and lost all compression.
Aug 15, 2014 | 1997 Pontiac Sunfire
What compression for 2001 chevy s10,2.2
Car is 12 years old, average mileage for that is well over 100K, so expect compression somewhere between 150-200 psi. Important that readings are still close together for balance, but you have some leeway there: Most manufacturers say lowest compression should be within 80 % of highest reading. Any cylinder with low compression (below 140 or 150) should have a leak-down test to pinpoint where compression is lost.
Mar 22, 2013 | Chevrolet S 10 Cars & Trucks
What kind of damage could i do to my dodge 2001 neon running with number 3 piston havng no compression
what probably happened is that when your timing belt broke the #3 piston most likely hit the valves hence the lost of compression. you will need to take the cylinder head off and have it rebuilt.
Dec 19, 2012 | Cars & Trucks
Over heated then lost power
probly lost compression in some of the pistons, do a compression test on all cylinders
Mar 12, 2011 | 1998 Isuzu Trooper
Husqvarna chain saw not starting. Seems to have lost compression. What should the compression be?
If its lost compression i would remove the two/three screws holding the muffler, take a look through the exhaust port at the piston, if there is any sign of scuffing or damage it is going to be cylinder off.
Nov 21, 2010 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Lost compression
Hello . I don't know what model we talking about but you should have over 100 psi of compression on the cylinder . If not you have to replace the piston rings and maybe the piston . Hope this help
Jul 16, 2009 | Garden
89 Volvo engine lost compression and broke spark plug
a new engine most likely, was it overheated?
Mar 23, 2009 | 1989 Volvo 740
Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi Logo
134 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
