Question about Conair Compact Garment Steamer Iron
Won't heat up or make steam. "low water" light stays on
2 Suggested Answers
  • 30 Answers
SOURCE: LOW WATER LIGHT stays on when water tank is full
Check the steam holes at bottom to see if holes is pluged with caculm build up that plug holes. To clean holes us calcum cleaner. Use decression . Use distalled water. Not tap water. There is probably a float inside of tank. Deposit calcum probably has stuck it. This is dependent on the brand and how old it is.
Posted on Mar 25, 2010
My steamer steams and then shuts off and it takes another two minutes to steam again....what is wrong?
the power light stays on but steam only comes out for 30 second.and it takes few minutes to steam again.
Oct 21, 2012 | Rowenta Commercial Garment Steamer - White
No steam from a grime buster steam cleaner what is wrong?
Check the water reservoir for clogg. Be sure that the cleaner has water on it and it is heating. .If not heating there you'll sure it won't give steam. Check the heating element for open or no continuity.
Heated water needed to generate or produce steam and you'll need a continuity tester to test it. Replace it with similar model and rating also with same size.
Good luck.
Jul 07, 2011 | Irons
Dear Fixya, The iron heats up but there is no steam coming out of my ''Stirella No Problem'' steam iron. Both the lights stay on and the green boiler light goes out and this indicates that the steam is...
This has worked for my SX8040D, but may not be a permanent solution. Fill the reservoir with clean tapwater - not demineralised or softened and not bottled water. Turn on iron and wait 20 minutes. Then try.
Jul 26, 2010 | Irons
DG 5030 steam generator-first time used and after...spits water
Common problem if you have the temperature or steam setting set too low (not enough heat/steam to vaporize water droplets or the unit is not up to full temp. I would have a clean towel alongside the iron to give a burst of steam prior to your first press...
May 29, 2010 | Rowenta DG-980 Iron
LOW WATER LIGHT stays on when water tank is full and no steam is produced.
Mar 25, 2010 | Conair Compact Garment Steamer Iron
CGS11DR CONAIR GARMENT STEAMER
Have you checked the float?
Sometimes that gets stuck, or collects mineral and stays in the last position.
Matt
Sep 14, 2009 | Conair Compact Garment Steamer Iron
Tefal program 8 500 Iron
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Mar 16, 2009 | Tefal UltraGlide plus 1656 Iron
Hi i have an edbs920 steam generator iron, my problem is that it will dry iron but wont steam up anymore, after turning the system on the power indicator light should turn from the flashing orange pre...
it can be that one of the thermostats controlling the water flow pump into the steam generator has become open circuit, caution is advised as this can potentially overheat the steam generator for there being lack of water, depending on your system design...i could be wrong just a guess !
Apr 30, 2008 | Euro-Pro Steam Generator EP8001 Iron
Conair steam cleaner sc20 - plugged in, pushed button, no steam
If you need instructions go to www.HandBookLive.com. There are videos for GS4 and GS10 under Appliances category. It says that steam is produced in about 5-6 minutes after you turn power on. Also there is a low water indicator light on GS10 that kills power to teh unit if the water level is low. Maybe that's the problem... Not sure if sc20 is similar
Apr 15, 2008 | Conair Compact Garment Steamer Iron
Conair Compact Garment Steamer Iron Logo
103 people viewed this question
Top Conair Irons Experts
Glenn Smart
Glenn Smart
D. E. Hev
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Conair Iron Expert? Answer questions, earn points and help others
