Question about Samsung SGH-a737 Cellular Phone
Cant turn my phone on...i dont know if its the baterry or the phone is just dead but i would like to fix it
Make sure the battery is fully charged, if you cannot check that, plug phone into charger and let it charge for several hours. If you still cannot turn on the phone, buy a new battery first as they are the least expensive to replace.
Posted on Aug 07, 2010
Hello, I bought a new mobile phone yesterday and now I have problem with switch on my phone. I was charge baterry and now I dont know how I can switch on. When I push a red button I only see at the moment...
Looks like the battery is dead, the li-ion battery's do not last longer than somewhat 2 - 3 years (or even less if not stored correctly) The manufacturing of this phone has been stopped for quite a while already, so i presume your one was just lying somewhere on the shelf with the battery slowly dying.
Try to switch it on with the charger inserted - if it does switch on it is definitely a battery problem. Maybe in the shop you'll be able to get an exchange, they should be definitely aware of the problem.
Mar 20, 2011 | Motorola Mobility RAZR V3
How to format china phone nokia 5130c-2 made in
Go to setting option than choose back to factory setting with code 1234 or 1122 or 3344.
May 05, 2010 | Nokia 5130 Cellular Phone
I cant turn on my fone
baterry contact pls check, if not working it's hardware problem.
Dec 18, 2009 | LG KF750 Cellular Phone
The phone blinks off in the middle of writing a text
I have the same phone... I LOVE THIS THING!
the only time mine will cut off is when the battery is dead. it gives no warning what so ever when I am talking on it. so I would wonder in your case that maybe you have a battery connection problem. see if the baterry is tight when you snap it in. clean the contacts also. hope this is a simple fix for you.
Jun 11, 2009 | LG VOYAGER VX10000 Cellular Phone
Battery not keeping the charge
the problem on it is the batery,, you must buy a class A baterry,, and make sure to follow the correct procedure of handling it, 1 do not overcharge 2 dont short circuit, and do not charge while you are using it,, replace the battery from a CLASS A type
Feb 13, 2009 | LG CU500 Cellular Phone
I cant use my keyboard normally from a distance
im assuming its a wireless keyboard so first i would make sure the baterries are not dead and second i would take the reciver out of the comp and make sure there isnt dirt in it. and finnaly if the key board has software try reinstalling it
Jan 06, 2009 | Microsoft Wireless Laser Desktop 4000...
My phone switch off so fast
first u have update the software by giving to an authorised nokia service centre and for the keypad u change the keypad and try
Oct 12, 2008 | Nokia N72 Cellular Phone
Nokia 3510i
maybe your phone is grounded if you a tecnician you can try to use hot air heat all board dont heat the C,P,U because C,P,U is im fortant and flash i,c dont heat maybe your phone is dead you can heat board just count seven and remove hot air and ready to next heat of board thats all
Aug 06, 2008 | Nokia 3510i Cellular Phone
My phone dosent turn on or nothinq
When the battery is totally depleted, you will need to use a charger that came with the phone. Sometimes it will take a few mintues (give it 10) for the battery/charging circuit to come on.
Sometimes you can charge from other sources than the charger that came with the phone. You generally will need enough charge on the battery to start the phone.
Example: If I have enough battery to where the boots and turns off, I can generally get it to charge from USB or my car adapter. You will need to get the phone to turn on and boot most of the way up before it will take a low current charge. If my phone is so dead it will not even turn on, I must plug it into the AC adapter. Sometimes even then the light does not turn on right away.
The problem is probably due to the number of amps provided by the charger. When the battery is totally dead, the charging circuit is drawing so many amps that it will prevent low amp chargers from being able to do the job. That's why these phones have such heavy duty AC adapters.
Apr 28, 2006 | T-Mobile Sidekick II
Samsung SGH-a737 Cellular Phone Logo
43 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
