Question about HP Photosmart C6280 Printer
I am attempting to connect my asus eee pc 1005hab to my fathers HP 6280 printer. Printer was and still is connected first to iMac(os-x).I am now trying to also connect to my Asus eee pc 1005hab but printer does not show up during installation.I can get as far as "select connection type" but after that I am unable to proceed because device is not found.I have tried connecting by USB , Ethernet port and wireless methods but nothing works. I have tried "search for device" every way possible but still not detected. Is my problem due to the original setup being done with Mac making the device unusable to my netbook or is it just a question of Windows 7 and netbook compatibility with this printer. I have , coincidentally downloaded and installed the most current HP printer drivers I can find via Driver Detective.
  • 352 Answers
SOURCE: not recognize usb printer hp laserjet 3050
Hi, I would suggest you update your printer drivers with fresh drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 21, 2008
Sailorm0on
  • 61 Answers
SOURCE: PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Posted on May 16, 2009
gewiz
  • 1263 Answers
SOURCE: Unable to install HP F380 drivers on Vista
well first of all uninstall the driver or drivers by going to the Control Panel, programs etc, if there driver is installed . Reboot, Now can you try another usb lead ? http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=&cc=us&lang=&product=1128296 now look at the post called Critical Update to Correct a PC to Printer Communication Issue download the HP Full Feature Software and Drivers install and connect the printer when prompt. Regards GeWiz
Posted on Jun 15, 2009
bschilz
  • 2049 Answers
SOURCE: Cannot install Laserjet 3050 printer driver on Vista 64 bits.
Try following this link and see if it helps you...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00843712&lc=en&dlc=en&cc=us&product=3390949&rule=27141&lang=en
HP seems to know there is an issue...
Posted on Aug 14, 2009
  • 156 Answers
SOURCE: My computer won't recognize (wirelessly) to my HP Deskjet
I'm sure you've tried installing the software with the printer detached...but if you haven't, that's the first thing. Another thing that's really common is that Vista may want to install its own drivers and they may not be compatible. Go into device manager (start-menu, right click on "computer", go to properties). Click on the hardware tab and let's get into device manager from there. Look for a yellow symbol with a ! in it. You can update drivers from there, navigating to the disk that you installed from...you'll likely see something that says "drivers" and either Vista or XP (If there's no Vista, try XP drivers anyway. Hope that works...
Posted on Jan 28, 2010
Remove asus eee harddrive 1005h
here is a place that will give you step by step directions
http://www.cesgeekbook.com/2009/12/asus-eee-pc-1005hab-tear-down.html
Feb 15, 2013 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
How can I connect HP wireless printer to my Eee notebook
Install the printer driver and connect the printer to your notebook using the USB printer cable.
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:-http://welcome.hp.com/country/us/en/support.html
Jun 03, 2012 | ASUS Eee 4G Notebook
What is the type cmos battery for the asus eee pc 1005hab
Hello alaskavet77,
i found this website where in they are selling batteries for all of the units/systems maybe it will resolve your question
http://www.battery-center.net/asus-eee-pc-1005ha-battery.html or you may wanna check this website
http://www.global-laptop-batteries.com/asus-laptop-battery/Asus-Eee-PC-1005HAB-Battery-Black.html
thanks :D
archiecruz30
Apr 05, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How to fit a keypad to asus eee pc 1005ha
Hello, Please follow the bellow link and you can solve
http://netbookitalia.it/asus-eee-pc-1008ha-guida-disassemblaggio-e-upgrade.html http://netbookitalia.it/asus-eee-pc-1101ha-smontaggio-componenti-hardware.html http://cegeekbook.blogspot.com/2009/12/asus-eee-pc-1005hab-tear-down.html http://cegeekbook.blogspot.com/2009/12/asus-1005hab-disassembly-tear-down.html
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
1005HAB ASUS Eee PC After five months of no problems out of the blue my blue Fn keys stopped working. Is there a fix for this? Any help would be appreciated.
you can replace the keyboard or you can send to a technician to clean and the check the connection of the keyboard.
Jun 30, 2010 | ASUS Eee PC 1000H Laptop
ASUS EE 1005HAB with Malware issue - Cannot access wireless
Avast is the best solution.Just you unplug the net connection and run the avast scan(from boot scan)
Copy the exe of avast from your pen drive and save it to your local PC.RUN it
Dec 15, 2009 | ASUS Eee PC 1000H Laptop
I have a brand new HP Colour Laserjet CP1215 printer purchased from PC World. I have an Apple iMac computer running MacOs10.5.5 When I attempted to install the new printer (to replace an HP Colour...
Not really a solution....this HP Colour Laserjet CP1215 printer works only in a Windows environment and is not compatible with Mac Os so I had to get another one and got pretty mad with PC World 'adviser' (?!)  who'd recommended the HP printer!!!
Dec 09, 2008 | HP Office Equipment & Supplies
HP Photosmart C6280 Printer Logo
135 people viewed this question
Seeker5211
Seeker5211
