Question about GE 36 in. JGP656 Gas Cooktop
One of the burners has a hard time igniting. Gas is emitting (can smell it) and you can hear the igniters clicking, but it won't light. If you go back and forth with the knob (on/off, on/off several times), eventually you can get it to ignite.
  • FritzyFritz Aug 07, 2010
    Helpful enough to know it's probably something I don't want to mess with. Natural gas is not your friend when you screw it up. I'll bite the bullet and call in a pro.
    Thanks
  • GE Master
  • 11,800 Answers
This happens because either the air gas mixture at that burner is too lean - you must take the top off and access the burner, there you will find a sleeve partially covering a hole in the pipe that leads to the burner, make the hole just a little smaller and try again - or the contact for the clicker happens too late - again take out the top and inspect the button for that burner, the electrical contact for the igniter can be loose.
If you haven't done that before and since this is gas you should call a certified repairman.
Posted on Aug 07, 2010
Left burner not lighting
Could be the igniter isn't sparking, sometimes they get cracked and run to earth you will still hear it click. Remove the top plate and check the wiring and igniters, turn the lights off and you will see if it's sparking all over the place.
Apr 03, 2014 | DCS 36" Professional Gas Cooktop W/Griddle
Center burner won't ignite
Try cleaning out the holes in the burner, specially near the spark.
Jan 26, 2014 | Frigidaire Cooktops
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Gas burners lit, but electronic ignition still clicks
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
fsggfs
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Burner clicks a long time before igniting you can smell the gas
Not sure about what part 1 is about. #2 indicates a failing ignitor gap or a bad gas mix. Get professional assistance.
Jun 13, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Gas cooktop BOOM
Gas is taking too long to ignite. Make sure the burner rings are installed properly. They have grooves that need to line up. Also make sure all the holes are clean.
Apr 03, 2008 | Cooktops
GE 36 in. JGP656 Gas Cooktop Logo
22 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
