Question about Casio G-Shock GW300CA-1V Wrist Watch
My g shock is solar and it will go from fully charged to plinking on low and then the next day its back on showing high and all i have to do is hit receive and its back up and running. its about 3 years old. it nowshow save in the upper left corner and not sure what that means
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
That sounds the same as car battery will do when it has a cell going bad. It's possible the battery has a defective segment, and will show a full charge for a while. It just doesn't have the capacity or amperage to run the watch properly. It could just need a reset on the Service Center equipment...or it could be a defective battery, even after only three years.
Posted on Sep 01, 2010
Why isn't battery recharging in sunlight?
Failure to recharge completely could be a sign of a failing battery.
Dec 03, 2015 | Casio Mens PAG240-1CR Pathfinder Triple...
Casio pathfinder battery operated watch keeps blanking out display?
Your watch is solar powered, so I think it isn't charged lately. At a low charge, the watch goes into saving mode by switching off the display (while keeping the time, date, etc.). To charge the watch leave it in a brightly lit spot for a day or two. That should be enough to make the watch function as normal again.
For more information, you can download the manual of your watch here (direct download link):
Timepieces Watches Manuals CASIO
Jun 11, 2014 | Casio Pathfinder PAG60-1AV Watch
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
G-Shock Atomic Solar watch - ERR in atomic time keeping
The watch will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
R/
David
http://antiqueclock.clockstop.com/
Mar 13, 2010 | Casio G-Shock Atomic MTG930DA 8VCR watch
I have a Casio Shock Risist watch (GW-500A) that says "charge" on the display, that is all it shows. Does it need a new battery or what?
this watch requires no battery. It uses solar cells. my watch did this as well. to make the watch functional again my advice is to not wear the watch for one day and place it near a window that gets a lot of sun.
Nov 24, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Watch has not picked up time signal for five days
Did you try to find solution here?:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Mar 30, 2009 | Casio GW800D 1V G Shock Atomic Solar Watch
Blank screen
if this is the same as my watch, it's solar powered and when it gets TOO LOW< it will blank out and begin to charge .  Stick it in direct sunlight for a day if you can.  You can also stick it under a regualr lamp, but it will never get fully charged, but it should be enough to operate at least.  The battery meter is the top middle dial on the face.
Nov 04, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Backlight doesn't work
Go to this link; http://world.casio.com/wat/download/en/manual/ and enter the four digit code on the back of the watch, you should get a user manual - i do think you are probably right however. Hope this helps :)
Apr 18, 2007 | Casio G-Shock GW300A-2V Wrist Watch
Casio 2654 mtg 901
sounds like it might not be getting enough sunlight. If it has the solar cell in it tape it to the inside of your window for a weekend. If it doesn't charge up the battery enough to make that bar quit flashing then you may need to have the battery changed.
Jan 02, 2007 | Casio G-Shock MTG900DA-8V Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
Top Casio Watches Experts
Ansel Alberto
Ansel Alberto
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
