Question about Dell 1600n All-In-One Laser Printer
The display reads open heat error. What is this and how can i fix it? I do not know where the manual is.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
An open heat error on a 1600n printer is a fuser error. You would want to make sure that the printer is not plugged into a UPS or power stripe. You would also want to make sure that there is plenty of clearance around the printer. If these are already in place then the fuser would need to be replaced. This is not normally a customer replacable item.
Posted on Aug 11, 2010
Teach me how to fix aircon says e1?
Hello, Mari-vick -
Without knowing the model number of your Aircon (an air conditioner, I believe), I can only provide you with generic instructions.
I hope you have the owner's manual and have checked there regarding the E1 error code.
If you do not have the manual, then . . .
Reasons for E1 error code, air conditioner:
1. Clean or replace the air filter. Note: Unplug the unit first. After cleaning or air filter replacement, plug the unit back in to the electrical outlet.
2. If the E1 error code still displays, it could mean one of the following problems:
- loose internal connections
- indoor and outdoor parts communications problem
- faulty control panel
Note: You may need an Aircon authorized repair technician for any such repairs.
Read more about the E1 error code on air conditioners and what may be malfunctioning here:
https://www.hunker.com/13407286/how-to-fix-an-air-conditioner-when-it-gives-you-an-e1-code
Best wishes.
May 08, 2018 | Heating & Cooling
Tip
How to fix the 3 red rings
Hello there
If you need to fix this problem or any other xbox problem like open/close tray error, disk read error, 2 lights error, all error messages, no display and son, if you want to fix this your self and save loads of cash on the way then you need a Good Xbox repair guide,
The Problem is caused by over heating and this causes the GPU and the CPU to lose connection with the motherboard, The heat actually melts the soldering that connects the chips to the motherboard.
The best advice i can give is as i say a really good xbox repair guide.
i use this website here to keep me updated with the best ones www.dr-xbox.tk
READ TIP ON XBOX REPAIR GUIDES
Thanks for using Fixya
on Jun 25, 2010 | Microsoft Xbox 360 Console
I need a service manual not a user manual for washing machine Electrolux EWS1277FDW
I suggest you first to check if there is any errors memorised in your washing machine, then we will know what is, a malfunction or improper use of the machine.
So, how to make a rapid reading of alarm codes, see below:
First, appliance must be in normal operating mode (e.g. during the execution of the washing programme, I suggest reading the alarm exactly when the washing machine working).
Press START/PAUSE and nearest option button simultaneously for at least 2 seconds:
The LCD display shows the last alarm.
The alarm continues to be displayed until a button is pressed.
Let me know exactly error code (Could be: first digit always "E", than following two numbers) if you read the alarm on display.
Dado
Feb 25, 2015 | Electrolux Washing Machines
Boiler not working
I would call the person or company who installed it. May be a simple fix you do not know about. You may have to wait till they open.
Sep 28, 2017 | Heating & Cooling
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
F-05 flashing on the display screen
Hi There
I have this for to read and hope this helps out. Let me know how this works out.
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Thank you for writing to fix ya.
Best Regards Richard
Dec 28, 2009 | Washing Machines
Ricoh FX16 open heat error
the Open Heat error indicates that the sensing circuitry for the fuser has detected that the fuser is not heating up. This can occur because either the sensing circuitry isn't detecting correctly or the fuser actually isn't heating up. Probably the latter in most cases.
How to fixya? Probably install a new fuser and you'll be fixed. Want to be sure before you spend $$ ?? Pull the fuser out. You will see a wiring hookup with two heavy wires that supply 110V to the heating lapm. Connect an ohm meter across the two wires that are on the FUSER. A good fuser will read around (0) ohms - complete circuit. A fuser with a bad lamp or a bad thermostat will read infinite resistance (open circuit).
The thermostat is probably available as a separate item. It's probably about $15 from several online sources. I believe you will need a JC47-00013A. I could be wrong. You'll need to do some research if you find that to be the problem.
Jan 26, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Microwave runs but does not heat food either with sensor or manual timing. Occasionall will displasy 'SENSOR ERROR'. Have closed door and pressed CLEAR/OFF per manual instructions, but still does not...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
INFO: On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
If the reset didn't fix it:
When you hit Start to cook, do the inside light and turntable come on?
Any unusual noises?
Is it louder or quieter than usual?
Do you have the model number?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Sep 07, 2008 | GE Microwave Ovens
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Dell 1600n All-In-One Laser Printer Logo
157 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
