Question about Philips Irons
Phillips steam system iron gc 8261 how do you clean calc system
4 Suggested Answers
SOURCE: How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
Posted on May 24, 2009
heatman101
  • 43501 Answers
SOURCE: My tefal pro express steam
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Posted on Jul 15, 2010
mcdevito75
  • 1970 Answers
SOURCE: how to clean anti-calc on tefal express steam
mcdevito75 here, I would try to clean it with some white vinegar.
Posted on Jul 28, 2010
What do I need to do to fix my phillips steam generator iron?
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please describe the problem you have with the iron.
Jul 31, 2014 | Irons
Calc-clean function light keeps flashing
Press the reset button
Nov 12, 2013 | Irons
Anti/calc iron water pours out from evry where
see this steps and fix it. God bless you
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2012 | Frigidaire Fcl222/H 2200W Steam Spray Iron...
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 | Bosch Irons
How to clean a phillips gc 8320 steam iron
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Hi,<br />Here is a tip that will help you with that problem...<br /><br />Cleaning a Steam Iron Soleplate</span></div> <div class="solution-text"><span><br /><a href="http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate" target="_blank">http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate</a></span></div><span> <div class="solution-text"><br />Cleaning a Steam Iron White Scale and Brown Water</div> <div class="solution-text"></span> </div> <div class="solution-text"><span><a href="http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown">http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown</a><br />heatman101</span> </div><!-- /solution text --><!-- helpful bar -->
Aug 26, 2010 | Philips Irons
Phillips Azur Precice 4340 , lost instructions . How do you de calc it ? Thank you . Claire
Fill tank with water and put steam setting to 0.Set temp pial to hottest setting. Let the iron heat up till the light in the hand goes out. Switch off power and hold iron over sink. Push down and hold descale button until all the steam and water has gone from iron. Wipe plate and heat up iron again with no water in it.
Nov 09, 2009 | Philips HI-296 Iron
Bought iron model no 14722 less than a year ago cannot find reciept for argos how do i get new iron or repaired
You could try the store but I don't think you will have any luck. I buy most of my electrical items from one local store, so if I have lost a rec eipt they can look it up on their system. I recommend a Phillips Steam Iron GC 4430 Don't buy an iron from a supermarket.
Sep 10, 2009 | Irons
Calc-Clean function
May 05, 2009 | Philips HI-296 Iron
Irons Logo
49 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
