Question about RCA RT2580 Theater System
The plastic clips broke that hold the speaker wires
Ge washing machine timer plastic clips broke
go to the manufactures website and request this clip from them or go to a scrap yard and look for the same machine to take the part out of it to replace yours eric
Dec 27, 2017 | GE Washing Machines
When changing a tire the jack cover broke, where can I get a replacement
dealer or scrap yard not usually an after market part try ebay
Jun 25, 2012 | Mercedes-Benz E320 Cars & Trucks
One of the clips on the back of my klh-HT-9930 speakers that holds the speaker wire in place broke off. Is there a way I can fix it or get a replacement part?
you can find replacements from radio shack or maplins. you may like to try a stronger type as the ones shown tend to be a little weak
Apr 10, 2011 | KLH HT-9930 System
How to remove rear door panel on 2003 Jeep
I am assuming you are asking about the 2003 Jeep Cherokee, these are the instructions for the Cherokee, if not, please repost your question specifying which Jeep you have.
Remove all screws securing the interior door panel on. There is a screw on the top portion, and two in the handle.
  • 2 Gently pull on the interior door panel to release the plastic clips that fasten the panel. Use caution to avoid damaging the plastic clips.
  • 3 With the door panel loose, release the two wire connections to the window- and door-lock switches. You must also remove the lock-mechanism poles.
  • 4 Remove the four screws holding on the speaker. Remove the wire connector and set the speaker aside.
  • 5 Remove the window seal by gently pulling. Make note of how each wiring harness is fed through the door panel.
  • 6 There are two clips that secure the window to the track. Using needle-nose pliers, gently pull the clips off of the window. Carefully lift the window out of the track and set it aside.
  • 7 Remove the motor from the track system by removing the three bolts holding the motor to the track. Remove the unit from the door and place it on a flat surface.
  • 8 Remove the lower cable guide by pressing on the tab with a screwdriver and releasing the guide assembly. You must also remove the window-guide mechanism. Make sure it is turned so that you can connect the cable in the guide.
  • 9 Install the replacement window motor and guide assembly onto the door panel using the three bolts. Make sure the cables are aligned properly before reinstalling the window in the vehicle.
  • 10 Install all peices in the reverse order.
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNocSDED
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNosJL4f
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNp4YDQ0
    Aug 23, 2010 | Audio Players & Recorders
    The orange plastic clip that holds in the battery broke.
    use some tape, or put a piece of something on top of the battery, when you close the battery door and latch it, it should hold the battery in place. That orange clip just holds the battery low enough that it comes in contact with the terminals at the bottom of the compartment.
    Hope this helps
    Jer
    Jan 16, 2010 | Pentax Optio T20 Digital Camera
    Drivers Side Electric window 1993 SC400
    The motor/regulator comes as an assembly with the wire and clips. You don't need to remove the window, just unbolt it from the regulator, and hold the window up till the new regulator is in, then remount it.
    Jun 10, 2009 | 1995 Lexus Sc 400
    Double cube fell and separated
    Use a Flat blade screw driver to take off both grills. Take both speakers out use a phillips screw driver. Put your fingers in the cube with the protruding grommet, turn the object until you see it protruding its maximum. Next align it with the opening in the other cube and press until you here it click back together. re-attach speakers and put grills back on ..Whala!!!
    Mar 16, 2009 | Bose Acoustimass 3 IV System
    HQ7825 Head retaining clip
    The clip that holds the head closed and on broke. It is a small gray plastic piece. model speed - XL
    Oct 21, 2007 | Philips Health & Beauty
    RCA RT2580 Theater System Logo
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
