Question about HP f2105 21" LCD Monitor
Hpf2105 Experiencing the same blue line problem. A month ago I had one bisect the screen. Today a 2nd blue line has appeared 2 inches to the left. VERY ANNOYING. What can fix it?
  • 472 Answers
If the lines are running top to bottom and are perfectly straight then your panel is failing.
The only repair is to have it replaced. It can be sent off and have the driver tabs repaired, but the sheer cost of that operation is far more expensive then a new monitor.
The next best option is to look for another monitor on a certain online auction site with a failed power supply and salvage the panel from that.
Even buying just a panel (new) will be more expensive or as expensive as a replacment monitor.
Sorry, it's just the way technology moves.
If it has any warranty left, then return it under that warranty. Most LCD's have a 3 year warranty, so it is worth checking up on. Look for the "Date of manufacture" on the sticker on the back of the monitor.
Posted on Apr 29, 2008
    New Friend:
I had this problem around '08 and my monitor is still functioning in 2013. All I did was add a little piece of paper between the screen and the edge of the monitor. I pushed it up into the monitor so as not to see the little piece of paper and it solved the issue. It has been fine ever since.
Posted on Jan 30, 2013
I have a 42 in Sony HDTV model # KDF-42WE6555. I notice a few months ago a blue line down the left side. TV still wking good. Today I notice a yellow patch on the right side. TV is still wking good except...
i have the same problem but mine has a blue line surrounding the screen the tech took out the fly wheel part from inside this part has the 3 main colors with strips the blue side strip if you look at the glass it has the problem you see on your screen you have to replace that one section
Mar 10, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Hi. I have a 46" Samsung LCD (LN4661) and
Ysus board and backlight inverter. Need to be replace. I there any sound?
Thanks,
Dec 11, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
Lines on Sony Plasma HDTV
it can be fixed but in this case i doubt its worth fixing. these problems can be astronomically expensive and personally i would buy a nice new bravia or something similar. please rate
May 11, 2009 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
A reflection light has appeared on the Sagem Axium HD-D45
Yes. A thin horizontal line that is always on red, green, blue, black or white is almost certainly a bad line in the display. If you purchased the display new, you should be able to get it replaced under warranty.
Nov 19, 2017 | Televison & Video
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
HP f2105 21" LCD Monitor Logo
114 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
