Question about HP Compaq nc6220 Notebook
I have recently bought a 4GB SDHC for use in a project I am building; When inserted into the slot windows does not respond nd the card heats up. I am running XP SP3, I have no other SD cards to compare. I have tried HP driver pakages sp30714, sp33439 and sp43509 {2.0.0.1 A, 2.0.0.1 A, 2.0.0.9 A respectively} with [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\tifm21\Parameters] "SDParam"=dword: premutations {0x00000010, 0x00000011, 0x00000001, 0x00000000} http://support.microsoft.com/hotfix/KBHotfix.aspx?kbnum=923293 reports that my version of windows is newer and is it unnecessary to install this. Any suggestions other than "install Linux", "use a debugger to inject the needed initilization into memory on startup" or "get another reader" since I do not have the time to install partition and install Linux, and the reader is in the mail.
  • Darren Aug 08, 2010
    New problem, somehow installing all of these different driver packages has uninstalled Adobe Pro. What else may have been affected?
  • Darren Aug 24, 2010
    Turns out that the connector had a bent pin inside, accidentally straightened it when it got stuck to a new 2 GB SD card.
  • HP Master
  • 20,706 Answers
Like the first post ever answering their own post
way to go dude.
hp has its own PDF view and sure if you load it
it changes the defaults from adobe.
Posted on Mar 14, 2017
SOURCE: memory stick / card slot not reading
thanks! totally worked!
Posted on Jul 10, 2008
proton77
  • 1183 Answers
SOURCE: how do you put in a sd card in the hp mini to display my pictures
Kindly read through the following ,link, that gives you the correct procedure to put the memory card in your computer and the compatible card list aswell.
According to the product manual , the follwing types of memory cards are compatable with your system
The Digital Media Slot supports the following digital card formats:
● Secure Digital (SD) Memory Card
● MultiMediaCard (MMC)
● Secure Digital Input/Output (SD I/O)
● Memory Stick (MS)
● Memory Stick Pro (MSP)
● xD-Picture Card (XD)
● xD-Picture Card (XD) Type M
http://h10032.www1.hp.com/ctg/Manual/c00766888.pdf
Thanks
Proton
Posted on Nov 30, 2008
1234s282
  • 144 Answers
SOURCE: SD vs SDHC on the HP mini 1000
Yes , SDHC is the name given to SD cards that can hold more than 2gb of data like 4gb or 8gb. they use the same slot as SD cards
Posted on Jan 05, 2009
XopenX
  • 108 Answers
SOURCE: HP Pavilion ZD8000 Digital Media Reader Issue
Try updating you drivers for your digital media reader. Also check your dcos to see if the DMR will read a 2GB card
Posted on Jan 15, 2009
kbdesign
  • 370 Answers
SOURCE: SD card wont work on HP nc8000 with XP pro.
Try this driver, and see if it will solve your problem.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=364182&prodNameId=364184&swEnvOID=1093&swLang=8&mode=2&taskId=135&swItem=ob-24461-1
Good luck, and please rate this response to your problem
Posted on Mar 15, 2009
I just bought a new sandisk 4GB card for my p880 kodak. Wnen inserted the new card camera screen says card is unusable, insert new card. I have followed instructions for formatting on my PC, but still get...
The P880 works with MMC and SD cards. Your new 4GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. The camera is limited to working with cards 2GB and smaller.
Sep 01, 2011 | Kodak EasyShare Z710 Digital Camera
I have an Exilim EX Z500 digital cam, the recent Micro SD that inserted to it have only 256MB that's too short.. so I bought a 4GB Micro SD card.. but why can't my EX Z500 accept a 4GB?
The problem is that your camera will only read SD cards, not SDHC cards, I checked its specification. You found your 256Mb card too small and bought a replacement, not noticing that it was SDHC. The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. I'm willing to bet that the 4Gb card you got is actually SDHC because 4Gb SD cards are so rare that I've even seen a guru on this site claim they don't exist. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it.
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
Jan 21, 2011 | Casio Exilim EX-Z500 Digital Camera
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Jan 15, 2011 | Pentax Optio S4 Digital Camera
CX7525. Inserted new 4gb sd card. Camera says it needs to be formatted. When I click on the "OK" button to format, it says "card needs to be formatted" again and again. Will not format...
There are no 4GB SD cards. "SD" cards larger than about 2GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 29, 2010 | Kodak EasyShare CX7525 Digital Camera
I have a digital photo frame Coby DP-5588. I bought a sd card Kington 4GB when I insert the card in the photo frame appears a message "wrong Card" and it doesn't read the card content. What can I...
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
Dec 05, 2010 | Coby DP-5588 5.6-Inch (4:3) Clock &...
I am having Intel pantium 4 computer that configration is windows 2000, when i am trying to read 8 GB memory card that drive is comming but at a time of try to opend masage is is comming as PLEASE INSERT...
It sounds as if you have an SD card reader, not an SDHC card reader. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. SD devices are limited to cards 2GB and smaller. SDHC cards begin at 4GB and go up to 32GB.
Nov 26, 2010 | PNY 4GB Secure Digital High Capacity...
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
I was trying to insert a new sdhc 4gb card in my powershot a540. Shows card locked error even if its not.
Nov 19, 2010 | Canon Cameras
Transcend 4Gb micro sdhc card
I had the same problem with Windows 10. Go to manufacture on your computer for SD card and reinstall the drivers..it should work fine..remember whenever dealing with Windows you may have to reinstall drivers...
Dec 16, 2017 | Transcend (589307) Media
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
http://en.wikipedia.org/wiki/Secure_Digital_card
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
HP Compaq nc6220 Notebook Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
