Question about Dometic Rooftop RV Air Conditioner
Roof top airconditioner stoped working after we washed our rv. (was working before) not sure if that means anything. cheked the fuzes
  • Dometic Master
  • 43,501 Answers
Probably not... just a coincidence...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 08, 2010
Sounds like fan is clicking on roof top dometic RV ac unit, but fan is not hitting anything.
check fan shaft and blade to make sure mud dober or mouse didn't build nest in there. if they did remove it and see if it works.
May 30, 2015 | Dometic Rooftop RV Air Conditioner
How to do a freon recharge on roof top rv airconditioner
there are no access ports to add freon you would have to put a line tap valve on it.
May 10, 2014 | Coleman Mach 15 Air Conditioner
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
Noisy roof top airconditioner
pull shroud and isolate where noise coming from.
Feb 17, 2013 | Dometic Rooftop RV Air Conditioner
Need to know over all height on a 1990 sterling rv
most vehicles cant legally be over 13 1/2 feet 13ft 6in tall in the continental us anyway..without an oversize permit..get a 16 ft tape measure and a staight 2by4 8 ft long. place the 2by4 on top of the main airconditioner on the roof of the rv(rear is normally higher by an inch or 2..balance the 2by4 so it goes over both sides..measure from the top of the 2by 4 all the way to the ground..this will give you its total height..post this number on the dash in plain view of the operator for future reference..I say the top because that extra 2 inches is the margin of error for you..good luck..
Feb 09, 2013 | Cars & Trucks
Have A Duo-Therm air conditioner on top of my motorhome and it stoped cooling, the fan works fine. Is there a fuse in the box under the filter? It says there is on the out side. I am not sure where it...
Can you please reply with model number off bottom of upper (roof) unit. Should be able to see it when filter is removed from ceiling assy. Please include model of thermostat if possible. You say fan works, but when turned to cool, no compressor kicking in? Try shutting unit off, and turn off breaker at panel as well, give it a few minutes and retry and see if anything changes and let me know.
Aug 16, 2011 | Dometic Rooftop RV Air Conditioner
Dometic roof top rv airconditioner is not pulling any water out of the air based on condensate run-off. Is this a sign of low coolant? If so - are these types of air conditioners equiped to be re-charged...
The system is not equipped to be recharged. However there are several options to add a service port to the system. If you are staying cool there is probably no need to add refrigerant.
Jul 10, 2010 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
TRYING TO FIND THE RIGHT DUCTED AIRCONDITIONER COLMAN. FOR 1995 TRAILER
The upper unit doesn't matter ( the actual ac unit on roof ) it's the lower control unit (inside at ceiling) that you need to change to use either ducted or non-ducted system. Any RV dealer can supply that, probably have it on the shelf. Just make sure you write down the model number and serial number, off the bottom of the upper unit, so they can match lower unit to it, for ducted system.
Apr 14, 2010 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
117 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
