Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
Trying to replace the fuel line and the primer hose both were rotted off not sure what goes where on my poulan pro ppb200 31cc string trimmer there are two lines into the tank the primer wont fill i have it into the tank but just bubbles when i try to fill it just need to know what it supposed to look like in the tank filter and a small hose coupling were just rolling around when i took it apart
    President:
  • Poulan Master
  • 1,545 Answers
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
Posted on Aug 07, 2010
Troy built trimmer fuel lines
normally the one nearest to fuel pump /primeer bulb is the inlet and the lower one is return
WHY can't you just connect hose to one and pump primer bulb to see what direction it goes ?
Jul 28, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Type of trimmer: Poulan Pro PP125 17-Inch 25cc 2-Cycle Gas-Powered Straight-Shaft String Have not used the trimmer in a couple years due to broken fuel line. replaced the lines today. The primer bulb...
Try cleaning your carb and even buying a rebuild kit. I do not think you have a blockage. Does it even try to start? Cleaning the carb will give you a chance to get rid of any debris or old gummed up fuel and oil that may be in there, give it a try. Good Luck...
Jun 04, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Apr 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
LOOKING FOR INFORMATION ON FUEL LINE ROUTING CONNECTIONS. FROM FILTER TO PRIMER BULB, TO CARB CONNECTIONS AND THEN TO RETURN BACK TO FUEL TANK.
most trimmer fuel lines run from line in tank with pick up filter to bottom of carby then out of top of carby to inlet on primer usually the smaller tube then out of the longer tube on the primer and back to the tank.
Jul 21, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Looking for the diagram for the gas tank for poulan pro trimmer PP325 SKU:952711457. All the parts fell apert inside the gas tank
You have two lines going into the tank, a small and a large one. The large one goes just inside the tank and connects to the top outlet just under the primer bulb. The smaller line has the fuel filter attached and lays on the bottom of the tank. The other end attaches to the lower outlet on the carb. Hope that explains it for you. Dwain
May 19, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
1,627 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
