Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
The pilot light keeps going out. I follow the instructions but it keeps going out. Can you assist?? RalphL.RLA@hotmail.com
  • Lite On Master
  • 3,328 Answers
Short pilot needs cleaning loose thermocouple at nut end , thermocouple might need replacing
Posted on Aug 08, 2010
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
Light pilot light
Many heaters have pilot flames can be relighted with a match or push button operation. Many employ safeguards to prevent unburnt fuel from accumulating in the space or allowing an unstable pilot flame from "proving".
Most appliances have instructions printed or embossed on or near the pilot, gas valve or protective cover. It is very important to closely follow these instructions for your safety and that of others in the area. If you are unable to locate the instructions or follow them and relight the pilot, you should contact the gas company for assistance. This can be in indication of an issue with fuel, thermocouple, gas valve, etc., and would require a service person to correct.
I have included a link to a video to light a gas heater - yours may be the same or similar:
How To Light The Pilot Light On Gas Heater
Feb 23, 2015 | Heating & Cooling
After following instructions numerous times I cannot get pilot to light on new LG water heater
Did you turn the gas on ?????
Just keep repeating the instructions.
It takes a while depending on what size the feed line is and how long for gas to enter the valve and then to the pilot.
It's can take mins.
This is the problem, the gas has not made it to the valve.
Even if the thermocouple is bad, no matter what the pilot will light, if the thermocouple was bad the plot would not stay lit and go out, but it will still light.
Like I said it can take a while.
Apr 14, 2013 | Water Heaters
How to reset a pilot lite
You have Reliance gas water heater with standing pilot light.
1) The problem is Pilot light is out and will not relight.
You followed instructions that show on side of tank.
2) Reliance has link offering help.
http://www.reliancewaterheaters.com/lit/om.html
3) Several things can cause this problem.
Some are easy and some are complicated.
Add a comment with more information, including what you have tried so far, for more help
4) Most basic cause for pilot failure: Maybe the thermocouple has gone bad.
Utube has a good video.
http://www.youtube.com/watch?v=v0aBPsNg6vo
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | Reliance WATER HEATER CO #1-30-YOPT-D...
Cover not sealed would that make polot keep going out
General causes for pilot going out: downward draft of air from outdoors, back-venting of furnace into water heater vent, bad thermocouple, or burner parts need cleaning, or bad gas control valve, or air in gas line.
Water heater in attic: hot attic conditions stop natural flow of vent gas upward.
Open following link for troubleshoot resources and cleaning illustrations and instructions:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Check venting by lighting a match under the vent hood and see if smoke drafts immediately upward.
Jun 25, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Bosch Water Wizard 10P - have no hot water, no water comes out the hot water tap, can't light Pilot Light, not sure where to start would love a step by step diagram how to start pilot light -...
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Before calling service technician, read manual for fault finding and possible solutions.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch_water-wizard.pdf
http://waterheatertimer.org/pdf/Bosch_13P_16P_In.pdf
Following links talk about keeping pilot lit, and describe location somewhat. Bosch water wizard has standing pilot light.
http://www.fixya.com/support/t2961646-water_wizard_10p_pilot_light_keeps_going
http://www.fixya.com/support/t2960079-bosh_water_wizard_10p_pilot_light_keeps
http://www.fixya.com/support/t6182021-bosch_10p_tankless_hot_water
1) The manual does not show diagrams you asked for.
2) Website that sells Bosch parts does not show parts for water wizard, nor does Bosch site for parts: Instruction manual says: replace pilot injector
http://www.boschhotwater.com/HelpfulResources/PurchaseParts/tabid/837/Default.aspx
http://www.houseneeds.com/shop/heatingproducts/waterheating/parts/bosch2400espartsbuy.asp#
3) Searching "pilot injector for Bosch Water wizard" turns up fixya questions which is generally bad news for do-it-yourselfer because it means information sources are through service technician.
4) As a general rule, tankless are not do-it-yourself repairs or installation because they are affected by so many internal and external factors, including air quality, air flow, venting, other gas appliances, gas pressure, gas supply, water pressure, water flow, plumbing problems, water quality, plus internal parts and including any combination of things listed above..
Replacement parts each come will disclaimer.
Add a comment with your experience so others with same-similar problem can benefit.
Send some photos so the internet can see the problem.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also take advantage of fixya expert assistance live.
Apr 03, 2011 | Bosch & Tankless LP Hot Water Heater
I have a Rheem gas furnace, model # RGAA-100C and need help lighting the pilot. The instructions on the metal plate tell me to set the valve to off, then to pilot, push the valve down until lit, and then...
Hi, follow what I say and it is very easy. The knob that says off, on, and pilot, is where you need to start. You don't want to turn it off now, as its been off for awhile now. Turn the knob slowly pushing down on it until you fill it go down. The knob will go down believe me. When this happens, keep holding it down as this is what starts the gas to the pilot which is back under the burner, under it. Just take a flash light and you can follow the aluminum tubing back and where it stops is where you light it with something long with a match in it or a small rolled up paper. Keep the knob down the whole time you are lighting it. When it lights, keep the knob pushed down for about another minute. Then slowly release the knob and the pilot should stay on. Once you have it on, turn the knob to on, not off. If you turn it the wrong way, it will go off and you will need to start over again. Once it stays on by itself, turn your thermostat up for heat and the burner will light and come on. Just remember that the pilot where you light it is where the tubing goes back under it, as the pilot gas goes through it. You will need a light. Look at the knob with a good light and it will tell you which way to turn it. In the pilot position, the knob will press down to let the pilot gas in, and you can reach back and light it. Then turn knob on. Pilot should stay light. Turn on thermostat and it will fire up. Let me know how it goes. You may have to try a couple of times.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 05, 2010 | Heating & Cooling
Intermittant flame, ignitor function is good, all other functions are as designed,timer ,tumble etc.
Hi
The pilot light flame would sometimes get very small and keep going out. This was usually because the pilot orifice was getting dirty and was partly plugged. The pilot orifice must be cleaned out when the flame becomes too small to light the main burner. You can blow air through the pilot assembly to help clean it out, don't use something metal in the pilot orifice hole or you risk enlarging the pilot gas feed hole and the pilot light may be too BIG. If your pilot flame keeps "going out", chances are you will need to replace the pilot latch do make sure the vent hood flapper is closing ok and no outside air blowing in is effecting the pilot flame.
This is a thermocouple that sensed the heat from the pilot flame and kept a small amount of gas flowing to allow the pilot light to stay lit. If you followed the instructions ( usually found inside the small access door on the front bottom ) on how to re-lite your pilot when it goes out and the flame will not stay on, replace the pilot latch assembly.
Please accept the solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | Whirlpool GGQ8831L Gas Dryer
Heating & Cooling Logo
160 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
