Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE Profile PSS26PSTB Freezer is not staying cold. Melting ice hovering 9 degrees instead of -6. Refrigerator seems fine
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
  • 531 Answers
SOURCE: GE Profile Side By Side Melting Ice but still freezing lower half
you have adefrost problem
Posted on Apr 02, 2009
  • 61 Answers
SOURCE: Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Posted on Jun 08, 2009
aasc
  • 1606 Answers
SOURCE: GE refrigerator, ice melts in ice bin
Since your refrig is cooling , I would replace the # 4 AND # 5 thermistors . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Posted on Nov 16, 2009
My GE Profile fridge freezer is having issues staying cold and also with preventing frost. Now it is melting from the ice bin.
If the auto defrost mechanism is not working, specifically, the defrost heater you will have ice buildup in unit and warmer temps all over. Check here for part(s) Search Over 2 1 Million Appliance Parts
Sep 07, 2017 | Refrigerators
Freezer forming ice stalagtite under ice tray
Sounds like the ice maker is allowing too much water in to the tray. There is an adjustment screw under the front cover of the ice maker. A 1/8 turn at a time counter clockwise will shorten the time the water delivery solenoid is open. It is possible that something foreign is keeping the solenoid valve to stay open too long, so it should be inspected too.
Jul 28, 2017 | GE Profile PSS26PSTSS Stainless Steel...
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Freezer not geting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Profile temperature going up and down
One of four problems,
1: this box has two sensors in the freezer... one on the top of the evap and one on the bottom left side of freezer cabinet (little small round white things) in the back lower portion of the freezer. These have been know to go bad and cause this problem.
2: you have a defrost problem caused by a bad main board or bad defrost heater.
3: you have a evap fan going bad on you, quits when frig gets to right temps. in other words the fan doesn't like the extreme colds,
4: door gaskets are leaking air around doors.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
Ice melts in the bucket on and off...
1check for frost 2 check light stay on 3 condenser fan 3 check door stay open
Mar 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
