Question about Tricity Bendix TM310W Electric Dryer
Dryer heating okay but drum does not turn. - Tricity Bendix TM310W Electric Dryer
  • Tricity Bendix Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
trwe43q
Posted on Sep 30, 2010
Kenmore 80's series electric dryer no heat...drum
Check your breaker by turning it off and back on. Then check wiring at plug and back of dryer. You could have a bad relay switch. You can find it under the top and put the 2wires together and try it then . If it works, you know that it is the relay switch. Last but not least, it may be your element. Check it visually to see if there is a break in it or a weak spot.
Feb 27, 2013 | Dryers
I have replaced the heating element in the dryer and started it but still no heat, the drum turns and there is air flow but no heat, its a whirlpool imperial series dryer
Check the breaker in your home. Turn it off then back on to be sure there is 240 VAC going to the dryer. Often times one side of the breaker will trip internally and even though it looks like it is okay, it can be tripped. Be sure to turn it off then back on.
Kelly
Mar 24, 2011 | Dryers
Dryer will not start but light comes on, heats drum okay. The dryer heats, the light goes off when the door closes, checked the drum and the belt is okay. When the start button is pushed nothing happens.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 30, 2010 | KitchenAid KEYS750LQ Electric Dryer
Gas dryer 4 yrs young and won't heat. Drum turns.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 04, 2009 | Televison & Video
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
Dryer does not heat
TRY CHANGING THE HEATING ELEMENT
May 03, 2009 | Dryers
Dryer timer still runs after auto-cycle is complete.
can you just leave the door open when not in use???????
Mar 30, 2009 | Kenmore Dryers
Model LEQ2152ES0
check the drive belt is on the pulleys
Jul 08, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryer not heating up
I just had Sears Kenmore come out to my house because dryer drum turned, but did not heat up. It was a circuit breaker. My dryer has two voltages, 110 for the drum and 220 for the heater. It was 110.00 for me to learn to press the circuit breaker. I hope this helps you. Karen
Dec 17, 2006 | Candy AQW130 Front Load Washer / Dryer
Tricity Bendix TM310W Electric Dryer Logo
46 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
Marvin
Marvin
ptpumpman
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
